Cadillac Racing Lifters Spec?
Old 07-06-2008, 08:31 PM
gsdave's Avatar
Default Cadillac Racing Lifters Spec?
What lift and spring pressures are the Cadillac racing lifters good for?
Also are they the same height as regular SBC factory hydraulic rollers? Crane says my stock replacements are not good for the amount of lift my cam makes. I hear good things about the caddy lifters and they're about $300 cheaper than the crane recommended replacements. Opinions?
This is for a 383 LT4.
Old 07-06-2008, 09:30 PM
z28_theantirice's Avatar
They are great lifters for the price. The pushrod cups were a lot shallower than what the stock lifters were. The overall body of the lifter is the same height.
Old 07-06-2008, 09:52 PM
gsdave's Avatar
So did you need a different length pushrod than with the regular SBC roller lifters?
Old 07-06-2008, 11:32 PM
TwoFast4Lv's Avatar
I had a friend Recently install them in his 07 Z06 and has a low oil pressure problem...as soon as he changed them back out for stock LS7 lifters he good to go again
To bad he replaced two oil pumps and took the new heads off to find it out
Old 07-07-2008, 03:14 AM
Village Troll
SS RRR's Avatar
Are they loose in the lifter bores? More oiling ports? I don't get it...
Old 07-07-2008, 04:39 AM
Gregory's Avatar
I have the lifters and like them. They are a little noisier than stock.
They are made for more stability at continued high RPMs.
If that is done through valving and springs I do not know.
The people a Scoggin-Dickey Chevrolet should know if you give them a telephone call.
Quick Reply: Cadillac Racing Lifters Spec?
