nitrous question.
Old 07-07-2008, 12:15 AM
Trick450r's Avatar
Default nitrous question.
well my nitrous setup arrived and i need to know everything else i need before i can start running it safely and efficiently like spark plugs, tune etc.
thanks
Old 07-07-2008, 12:28 AM
dre2013's Avatar
ngk tr6 plugs gapped around .035 (someone else chime in here, i forget the exact spec), WOT switch, FPSS, window switch, ign box to make it safe...good choice on the wet kit. depending on how large of a shot you might want to get it tuned also. what size shot?
Old 07-07-2008, 12:29 AM
99problemz's Avatar
You might want to upgrade the fuel pump
Lots of useful info on here
https://ls1tech.com/forums/nitrous-oxide/846230-everything-nitrous-related-stock-bottom-end-all.html
