Should i put a little loc-tite on rocker-arm bolts?
Re: Should i put a little loc-tite on rocker-arm bolts?
I do have ported heads. Why would that make a difference?
What number loc-tite should i put on 262?
When heads are ported, the rocker arm bolts will protrude down into the intake ports, meaning its a passage oil could seep through and get into your combustion chamber. The locktite on the bolt will sorta act as a sealer for it.
I use whatever is in the red tube, the loctite fluid itself is blue.
lol there are many many different kinds of loc-tite in red containers. Some of the fludis are red and some are blue.
Any way thanks for helping also i want to thank you for you web site it is very good.
