Any reason not to run a bottle with my set up?
Help me out guys.
I have a 99 Z28 with 34k miles on a forged 383 running 9:1:1 compression that is fully built to accept an ATI Procharger. It has Stage 2 AFR heads, Comp Cam, 60lb injectors, Mac Ceramic Headers, Mac Y Pipe (no cats), Corsa 304 Exhaust, Underdrive Pully, Mac SFC, Eiback Springs, HAL QA1 adjustable shocks, BMR F/R Sway Bars, BMR Control Arms, BMR Pnhard Bar, ATI Balancer, B&M Short Throw Shifter.
The problem I have is I ran a little short on cash and didn't finish the job, basically postponed the blower install. I spoke with Bob at EPP and when you include a 9" rear plus upgrade to the fuel pump we are talking 9k-10k. Basically I have to wait a while.
Having said that, I can manage $2k right now for a nice Nitrous system.
Any reason not to do that? I am patient enough to wait for the charger but not enough to keep running a motor with less hp than what I had before.
Thoughts?
Thoughts?
INVOICE
#011734
Terms: 50% Deposit
Muskegon, MI 49444 Cash upon completion
May 15, 2007
4.00” STROKE
3.905” BORE
9.1:1 COMPRESSION
383 CU IN3
LABOR INCLUDES:
• Disassemble complete engine
• Clean all parts & analyze
• Degrease block
• Rebore cylinders with torque plate
• Align hone main bearings – check
• Check deck
• Grind & mill for stroker crankshaft
• Assembly clean block
• Competition valve grind
• Replace valve guides – 16
• Hone valve guides
• Resurface heads
• Bead blast heads
• Degrease heads
• Degrease intake manifold
• Magnaflux crankshaft
• Complete balance of the rotating assembly
• Polish & chamfer crankshaft
• Hone pistons to fit pins
• Install pistons onto rods
• Install & fit cam bearings
• Install expansion plugs
• Check bearing clearances – mains & rods
• Assemble complete engine . . . . . . . . . . . . . . . . . . . . . . . . . . . $ 2,769.00
PARTS CONSIST OF:
• Clevitte cam, main & rod bearings
• Eagle 4340 4.00” stroke crankshaft
• GM vibration damper*
• Eagle 6.125” connecting rods
• Diamond pistons & ring set
• Ferrea intake & exhaust valves
• Valve guides
• GM timing chain set
• GM head bolts*
• Cometics head gaskets
• Fel Pro performance gaskets
• Melling oil pump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . $ 4,035.04
PREP FOR PROCHARGER UPGRADE:
• Chassis dyno & tune
• FAST 60#/hr fuel injectors . . . . . . . . . . . . . . . . . . . . . . . . . . . $ 983.55
*UPGRADES:
• ATI damper
• ARP head studs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . $ 645.82
ADDITIONS:
• DUAL FRICTION CLUTCH ASSEMBLY . . . . . . . . . . . . . . . . . . . . . . . . $ 428.83
SUBTOTAL . . . . $8,862.24
SALES TAX . . . . $ 335.59
FREIGHT . . . . . $ 70.59
TOTAL . . . . . . . $9,268.42
LESS DEPOSIT . . (3,500.00)
BALANCE DUE . . $5,768.42
With what you have the head bolts may become a factor around 250. I know Diamond makes good pistons. Different versons of there pistons are rated for diffrent amounts of boost and nitrous. Being that your motor was built for boost I would expect the pistons were rated for atleast that. I have to say I am suprised they used the GM torque to yield bolts..
Dave
Dave
Dave
Dave
on the D-1SC with an 8 rib.
Any kit in particular you guys recommend? and I like the idea of 2 bottles sitting back there. I know is more for show than anything else but what the hell
Thoughts on that?
Wow,
The stock intake is going to deffintly choke it down assuming you have some good flowing heads. Personally I am a fan of doing it right the first time. The system I would recommend would depend on your plans, classes you may be racing in, and budget.
The Victor JR is a great choice for a stroker engine with a high flowing top end that will be turning RPMs of 7000 or more. It will take alittle from the low end torque however it will make up for it on the top end.
Dave
Dave
Wow,
Dave
Dave
My budget is $1,500.
