Are TR6 plugs available in Platinums ?
Hi Guys
I'm too lazy and changing plugs on my Twin Turbo 408ci Setup is a pain in the **** .
I have to unbolt my Dump pipes in order to get to them !!
Are Tr6 plugs available in Platinuims from NGK ?
If I could get around 80,000 khms from a set it would suit me better .
I'm only running 16 psi using Garrett Gt3076s and 2 Tial 38mm gates.
You will blow the plat discs off the plat plugs in a FI app, I wouldn't use them...Just use TR6's and gap them a little tighter (.020) or so. The gap can spread a bit over time.
ARe you sure ?
I was running NGK TR5 Platinums for 2 years on 10 pounds Turbo setup with no problems ?
Does anyone know the TR6 equivillent to Bosch fusions ?.
