Tps?
Old 07-08-2008, 12:01 AM
Sparkinak's Avatar
Default Tps?
I have a problem with my TPS. If I plug it in it will not rev up. If I unplug it, it will stumble a little bit but it will rev up. I have checked my wireing as it is a custom harness and they all go back to the correct pins on the pcm. The TPS is off of a 72mm truck throttle body, and it was put onto a l92 intake with the 90mm Holley Throttle body. The tune was for a stock 6.0 truck intake. Don't know if any of that info helps but I can't figure out why it won't rev while its plugged in.
Old 07-08-2008, 12:39 AM
fuseone's Avatar
did it rev fine before with it on and the just occour now?
Old 07-08-2008, 12:50 AM
Sparkinak's Avatar
This was all first time shot. Never ran before the motor swap... So I don't have a baseline.
Old 07-08-2008, 07:24 AM
69LT1Bird's Avatar
Connect a meter to the TPS to see of it is reading correctly. It is a basic pontentiometer. With it plugged in and key on, you should have about 0 volts going back to the PCM and 5 volts at WOT.
Old 07-09-2008, 08:54 PM
Sparkinak's Avatar
I checked operation, I got 5 volt reference, I have .4 volts at idle, and I got 4.65 at WOT.
Does this mean I have a bad PCM?
Old 07-10-2008, 10:29 PM
Sparkinak's Avatar
Come on some one has to know how to fix this!!!!
If I unplug the sensor it will rev up kinda sluggish but it will, If I plug it in and try to rev it, it will climb 2-300 RPM and then shut down like it hit a rev limiter. Then it will start to surge for 5-6 times and then level out. Is it something easy dumb ground, PCM
Old 07-11-2008, 10:25 AM
Richard@WCCH's Avatar
Look up DrX on this site. He has vast knowledge of the DWB ttbs on truck applications
Good luck,
Richard
