some ?'s on shocks , suspension for street use
Old 07-08-2008, 12:11 AM
Restricted User
Lawnboy's Avatar
Default some ?'s on shocks , suspension for street use
I have a 01 SS camaro, Procharged, methanol injected,
It is a street car, I use it mostly for street cruse, street drag, maybe a track day or two once a year, so what i am saying its a street car.
OK i need some advice on some suspension mods,
Of course i will be installing a set of weld in rail sub fram connectors, the ones you can see from the side of car,
A spohn bolt in tq arm with built in driveshaft loop
some rear control arms, maybe adjustable
Ok on Shocks , i was interested in some that will perform good over the stockers, ones that will be good for street use with out making the car feel sloopy
Please help
thank you
Old 07-08-2008, 02:51 AM
transwiz's Avatar
You will get a lot of opinions on shocks.Do you want a car to handle on curves too or are you concerned with only straight line drag racing?
I wanted a car that would be good for stoplight racing and would be glued to the ground on curves in canyons.My choice was the koni sa shocks.It depands on your budget and how you want your car to perform.
The koni's ride really nice too.
_________________________
2000 t/a ws6 with lots of mods
Old 07-08-2008, 03:31 AM
nighthawk15's Avatar
You say its a street car, but its still not clear what you're after. Do you want the best all around performance, or are you after a drag shock?
Old 07-08-2008, 06:48 PM
Restricted User
Lawnboy's Avatar
best all around performance, but something that works good dragging
Old 07-08-2008, 06:49 PM
Restricted User
Lawnboy's Avatar
any part # on those Koni's
I was think on them from the beginging
Old 07-08-2008, 09:43 PM
Koni SAs (single adjustable, man. No other way to go. I'm not sure what the PN is. Just order up a set from your favorite speed shop.
Old 07-08-2008, 09:45 PM
JD_AMG's Avatar
You wont be disappointed.
http://www.stranoparts.com/partdetai...ID=0&ModelID=7
Old 07-08-2008, 11:09 PM
Restricted User
Lawnboy's Avatar
they are adjustiable? how ?
Old 07-09-2008, 01:18 AM
Foxxtron's Avatar
Even though you mention it's street car, I'd like to include a link to this very informative sticky:
https://ls1tech.com/forums/suspension-brakes/643950-suspension-mods-real-world.html
The member who wrote this is spot on. FWIW, your street car will have some compromises, though what I can say is that you might not have to spend much to get a lot in return, provided your goals are realistic.
Old 07-09-2008, 03:46 AM
transwiz's Avatar
Call strano and talk to him about shocks.They are good people and are happy to spend the time to talk about what will be good for you.
____________________________
Old 07-09-2008, 05:00 AM
twitchtwice's Avatar
if you have the money, get the koni's if not, wait and get koni's. thats what i hear all day long.
Old 07-10-2008, 01:59 AM
Restricted User
Lawnboy's Avatar
OK i am convinced , I will go with the koni's
which ones for the front and back, please let me know
and when you mean single adjustable, what do you mean , are they 60/40 70/30 90/10 or something else
Old 07-10-2008, 02:18 AM
Foxxtron's Avatar
Of course my vote goes for the Koni SA's, however I think that anybody should call their vendor of choice and arrange all questions before spending any money, even on well engineered and warrantied items. Direct conversations with the vendor you'll be purchasing from helps to really establish the consumer to vendor relationship for customer service and technical support questions.
My vendor of choice would be Sam Strano, whom you may want to call.
Old 07-10-2008, 06:30 AM
z28bryan's Avatar
Konis have adjustable rebound. Compression stays the same. That's ok though as most springs don't really need the compression adjusted for the suspension to work properly.
I'd also recomend Konis if you are just doing the track once in a while and not planning hardcore drag racing.
