Gains in 1/8 mile ....ET's?
Old 07-08-2008, 11:13 AM
mikenews's Avatar
Default Gains in 1/8 mile ....ET's?
Would could i expect to see for a gain in the 1/8 mile when going from 2.73's to 3.73's. Or should I just do a stall??
Old 07-08-2008, 11:32 AM
junior28570's Avatar
Yes but not a whole lot. I would stall it before the gears. Bolt-on A4 cars are capable of low 12's, high 11's in the 1/4 with a stall. Gears alone will not get you there.
Old 07-11-2008, 11:02 AM
mikenews's Avatar
wow I'm surprised no one else has data. BTW thanks junior for reply.
Old 07-11-2008, 03:02 PM
2nd3rd4thgen's Avatar
i gained 3 tenths in the 1/8 form going with 2.73 to 3.42 other than that i was bone stock if thats any help.
Old 07-11-2008, 08:47 PM
mikenews's Avatar
that's what I'm looking for... I would be happy to gain 3 tenths! Cool,,,thanks!
Old 07-29-2008, 06:07 PM
seminolefamz28's Avatar
U have to start with the gears first then the stall i gained 4 tenths going with the 373's and headers
Old 07-29-2008, 08:50 PM
firefighter813x's Avatar
Since your unlucky and have the 2.73's I'd change the gears with the converter. Of course, tire diameter and all that other stuff comes into play as well. There are plenty of threads, and even stickies about this if I am correct. Good luck.
Old 08-07-2008, 06:16 PM
blown03mustang's Avatar
you need to get gears and a converter at the same time! your converter needs to match your gears! you should pick up quite a bit tho
