Xylene, octane booster
Old 07-08-2008, 11:39 PM
Caribe's Avatar
Default Xylene, octane booster
For those using Xylene and Marvel Mystery oil mix for an octane booster, do you mix the xylene/oil and fuel outside the tank then add. Or do you add the xylene/oil mix into a known quantity directly into the tank. in other words if I have 10 gallons in my tank, can I just add a 2 gallon mix in? Thanks
Old 07-10-2008, 10:56 AM
Cmarsh's Avatar
Thats what I did, just added to the tank and drove around for a bit to mix it up. Its WAY cheaper if you buy xylene in a 55 gallon drum from your local chemical supply store...I remember it being around 150 or so
Old 07-10-2008, 07:23 PM
OUTLAWZ RACING's Avatar
Sorry for being dumb .... But what the hell is xylene?
Old 07-10-2008, 08:51 PM
Caribe's Avatar
I have not seen any big drums of it here on island. I can get by gallon at Home Depot. It is still expensive, but there is no race gas here. Xylene is a chemical that is used for paint stripping that is around 116 octane. People mix it with gas to avoid detonation while on boost or nitrous.
https://ls1tech.com/forums/showthrea...ghlight=xylene
Old 07-11-2008, 07:18 PM
Coreyc619's Avatar
toluene is fairly effective also and it can be picked up at a hardware store as well.
its been so long since ive needed it i dont remember how i used to mix it.. but it may help you and could be worth looking into. but where i live im in the armpit of the USA.. we do a shatpile of oil refining around here so high octane gas is plentiful
Old 08-10-2008, 04:45 PM
tillery's Avatar
I usually pump around 1000 gallons of XYLENE at a time down hole to clean out oil wells. Very flammable! I stick to the pump gas.
Old 08-10-2008, 04:48 PM
tillery's Avatar
And BTW- XYLENE will melt soft materials-like rubber of any hardness, and read the MSDS on it as for any other chemical.
Quick Reply: Xylene, octane booster
