Hesitation on upshifts
Over the past couple months, progressively more often, I've been getting hesitation for a second or two when I upshift. It doesn't happen every time and it's only if I upshift and the rpm's drop below 2,000ish. After a second or two it's fine until the next upshift. Shifting faster seems to reduce the chances of it doing it. Any ideas on what could be causing it? I've tried Seafome and 44-K. O2 sensors maybe???
Start small, try a fuel filter, if its bad enough, you'll be plesantly surprised!
https://ls1tech.com/forums/showthrea...de+fuel+filter
