K-member/Control Arm Bolts
Anyone know where i can get some nice k-member and front control arm bolts? I would like to replace them all, the Control arm bolts and nuts, and k-member to frame bolts. I am flabergasted that no one sells an installation/hardware kit with an aftermarket k-member. Is everyone re-using stock bolts or if not, what are you doing? Thanks! Also, what are you doing with your brake lines with the aftermarket K-member?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
thank you! I wonder if they will all work with the BMR Kmember
__________________
