NX intake, 85mm TB, NXL system for sale
wanting to change my setup to a vic jr intake. so, i am selling my whole setup.
NX intake (designed for the NXL system has nozzles molded into the intake)
NX 85mm TB
NX NXL nitrous system (complete with wiring and painted black 10lb bottle has gauge on bottle)
dual purge solenoids with v purge blocks
jetting for 90, 120, 180, 250 (made 225 rwhp with the 250 jets)
NX fuel accumulator
modified stock intake bolts
intake painted silver
in total this setup costs $2975.00
will take $1800.00 + LS6 intake, stock TB, stock fuel rails, stock intake bolts. will considered other options.
i'll pay for shipping to send you my stuff. you pay for shipping to send me your stuff.
video of the dual purge in action
pics of intake assembled off the car NOTE: FUEL INJECTORS NOT INCLUDED
here's pic of the setup on the car.
NX 85mm TB
NX fuel accumulator
thanks for your suspicious smilie. have other things to buy as well. as you know from other threads i popped the head gaskets on the motor. along with that, i found a crack in the #7 exhaust port today. this necessitates me buying new heads now. for now, i'll run the stock stuff, until i can get the vic jr, and all the other supporting components to convert over. here's pic of the wonderful crack. hate to be thought of as a suspicious character.
i may even go L92 heads. GMPP makes a carb intake for those heads as well.
I was trying to find a scratching head smilie, that was the closest I could find, haha!!! Um dude, if I might give you a little advice, stay away from the vic jr, i've heard nothing but bad things about it from everyone I know that's used it and have seen quite a few cars go slower with it than they did with a fast 90, if ur gonna go carb style get the GMPP and make sure you have it port matched to ur heads.
understood on the smilie. i've read about some of the results with the vic jr taking some off the low only to be able to extend rpm range well above 6500 rpms. so, i've been tossing it around. i'll look into the GMPP intake as well. i'm comparing the pricing on going L92 stuff. if i go L92, i have to do it all at once.
ive heard the elbow is what kills most of the carbs performance. When i looked into it a bit more, i saw a bunch of the fast guys running the accufabs and they seemed to work very well for those setups. GL robert
