Will LS1 edit log diagnostics like autotap?
Old 08-21-2003, 09:02 PM
black_z's Avatar
Default Will LS1 edit log diagnostics like autotap?
Tried searching but couldnt find an answer.
Old 08-21-2003, 09:27 PM
slow's Avatar
Default Re: Will LS1 edit log diagnostics like autotap?
no, edit is just a programmer
you need both a scanner, and edit sorry.
Ryan.
Old 08-22-2003, 12:00 PM
miner_49's Avatar
This question seems to come up once a month. You need to buy Autotap, EFILive or EASE scanner software to be able to use LS1 Edit.
In fact you should buy the scanner software first as it has some uses in troubleshooting your car. While LS1 Edit is useless by itself unless you can borrow someone's scanner software.
Old 08-23-2003, 04:13 AM
1320_PERFORMANCE's Avatar
Gm's tech 2 scanner, that can be used with ls1 edit right. am i right or wrong? cause where i work i have acces to gm's tech 2.
Old 08-23-2003, 11:11 AM
MNC5's Avatar
The Tech II can be used as a scanner for tuning.
Old 08-23-2003, 11:48 AM
LS1TECH Sponsor
Magnus's Avatar
You can scan using the LS1 Edit cable...but not with carputings software..
More info is on the PCM Hacking forums:
http://pcm.dxsoftware.com/forum/
Old 08-23-2003, 08:28 PM
Right on, thanks guys, now jus need a laptop.
