Bad sound from Rear suspension after upgrades!
Ok Well I recently installed all of my suspension parts on my firebird. I installed:
UMI Pan hard bar
UMI Upper Pan hard bar
UMI LCA
Strano lowering springs
Basically when I go over speed bumps or hit ruts in the road it makes a pretty loud knocking/banging sound. No noise on smooth roads or around bends. ONLY bumps of any kind
Im wondering if its my stock struts. I still have the decarbons with 95,000 miles on them. Its like they arnt stiff at all and there is no dampening of the shocks so it bottoms out or somthing. IDK any ideas
UMI Pan hard bar
UMI LCA
It is most likely the shocks. Granted, until last weekend I had DeCarbons with an Eibach pro-kit at 84k and it wasn't doing that, but I can't think of what else would cause your issue. If you had LCAs with rod ends, I would say that you may have bolts that are slightly too small. Not likely the case with poly bushings but it would probably still be a good idea to check for play in the LCAs.
Make sure everything is torqued correctly. I had a bolt on one of my LCA's that wasn't quite tight enough and it made me think the whole rearend was coming unglued.
I would check (in order):
Lug nuts
LCA bolts
PHB bolts
Shock bolts
Spring isolators (make sure the spring is properly seated and not doing the metal on metal dance)
-Mike
Lug nuts
LCA bolts
PHB bolts
Shock bolts
-Mike
yeah, I spent most of yesterday tracking down my clunk....PHB jam nuts were loose, along with the mount on the dr. side lower shock point. Sounded like the whole car was going to fall apart!
