converter locking on 1>2 shift. HELP!!!
Old 07-10-2008, 09:50 PM
thebulgd's Avatar
Default converter locking on 1>2 shift. HELP!!!
when my car makes the 1>2 shift the TCC trys to lock, it goes into mode --3-- and TCC slip goes negative. TCC apply and release tables are set to 256 for second gear. What else should I be looking at? WTH is causing this?
Old 07-12-2008, 12:18 PM
thebulgd's Avatar
anyone? any ideas? no one has had this problem before?
am I asking the wrong questions?
Old 07-13-2008, 09:03 AM
gojo's Avatar
Upshift TCC Lock should be set to NO!
Old 07-13-2008, 03:30 PM
thebulgd's Avatar
shift lock is disabled, lock-up tables for 2nd and 3rd are maxed out.
Old 07-13-2008, 05:08 PM
gojo's Avatar
I'm not familiar with HPT scan tool. If you can, log for TCC signal to apply. See if there's a command to apply in 1st or 2nd. There should not be one.
Dana at Performa-Built probably can help.
