a/c question
Old 07-10-2008, 11:41 PM
robsquikz28's Avatar
Arrow a/c question
has anybody ever split the case on the lt1 evaporator and just removed the evap then installed it back in the car with the blower motor assembly and box still in tact. it would be like a non a/c car correct? lets hear the ideas
Old 07-11-2008, 06:59 AM
aaannnnnnnyyyyyyyyy1111111111111
Old 07-11-2008, 08:21 AM
the_merv's Avatar
These are close-up pics of my AC Delete Panel that I made. Pretty much did what you are asking..
Old 07-11-2008, 08:53 AM
ss.slp.ls1's Avatar
I just installed an AC delete pulley and left all the lines intact, in case I ever want to go back to AC.
Old 07-11-2008, 10:46 PM
looks great but the question is did anybody ever split the case in half and just take out the evap and put the box back with the blower motor assembly in tact.
in other words it will be a non a/c car with heat only like a factory type car.
Old 07-12-2008, 06:46 AM
the_merv's Avatar
Why run that big chunk of **** in there when there is nothing in it..?
Even the 1LE Cars that did only have Heat still had a Delete Panel.
Old 07-12-2008, 08:57 AM
see thats the answer i was waiting to hear i was wondering if that big box was just useless and the blower motor and the heater core were seperate from that bulky *** box. if this is true that means bye bye ugly box
Old 07-12-2008, 01:47 PM
the_merv's Avatar
It is seperate..I'll find my pics and post them for ya, you will see..
Old 07-12-2008, 07:24 PM
ok let me know if youd like just pm them to me thanks merv
Old 07-13-2008, 01:49 AM
the_merv's Avatar
Here is what I have..
You have to cut out some plastic and make a pathway for the Air from the Blower Motor..if you don't you will have no heat.
Attached Thumbnails a/c question-blower-duct3.jpg
Old 07-13-2008, 09:11 AM
ok i see what you have there now do you still have a panel there or not. i see that you have your heater core there but plugged at the ends and the blower motor is there as well. did you just cut the box at the firewall.?
Old 07-13-2008, 03:53 PM
the_merv's Avatar
Yup.. cut it flush and put the Panel over it.
Old 07-13-2008, 05:26 PM
fantastic thanks
Old 07-27-2008, 11:39 AM
FASTFATBOY's Avatar
MERV Can this be done with the engine in the car?
I am about to get serious with the weight reduction, gonna do what is in this post and remove the passenger airbag.....Still want my heater though.
40lbs ya think?
Old 07-27-2008, 01:00 PM
the_merv's Avatar
It's about 40lbs.. I don't know about with the Engine in the Car.. I'm sure it can be done, but that will be a feat..that's a tight spot.
Old 07-27-2008, 01:07 PM
FASTFATBOY's Avatar
These plates can be bought, who sells them?
D
Old 07-27-2008, 01:09 PM
the_merv's Avatar
You mean the AC Panel that I made..?
Old 07-27-2008, 01:13 PM
FASTFATBOY's Avatar
Yes, that panel.
Also when I take the dash out to remove the passenger airbag, the whole evap box should come out from the inside, correct?
Old 07-27-2008, 01:17 PM
the_merv's Avatar
Yea, that whole box comes out from the inside.
As far as the Panel goes, I think BMR makes one..
Old 07-28-2008, 09:26 AM
BMR Tech's Avatar
We do offer a A/c delete panel for your application. The panell uses all of the stock air box mounting holes to make the installation as clean and easy as possible. The panel can be found here
http://www.bmrfabrication.com/misc.HTM
Let me know if there are any questions I can answer for you
Attached Thumbnails a/c question-fp003.jpg
