95 LT1 and T56 4 sale
95 lt1 T-56 swap
modds
CC 306
CC valve 918 spring
1.6 rocker
58MM TB
Accel 30lbs injector
accel 8mm wires
NGK plug
MSD cap & rotor
MSD coil
cold air intake
K&N filter
new GM alternator
THIS IS A COMPLETE LIFT OUT PACKAGE, COMES WITH ENGINE, TRANSMISSION, STARTER, ALTERNATOR, COMPUTER, ALL SENSORS, , MASS AIRFLOW SENSOR, POWER STEERING PUMP, EVEN THE BELTS ARE INCLUDED AND ENGINE WIRING HARNESS. The PCM has been tuned by PCM for less and it has the LT-4 SCM in it to and it come with all the stock motor parts to. The motor and tran has about 80k in then.
I am asking 3000 or BO
My email is ijtravaille@yahoo.com
Here are some pics of the motor
and a video of it running can post more video if need and can drive the car if need
http://s259.photobucket.com/albums/h...urrent=066.flv
++ The motor makes very good power. I ran red_Z28 when he had his slick on. I won by 3 to 5 car when he was on motor.
modds
CC 306
CC valve 918 spring
1.6 rocker
58MM TB
accel 8mm wires
NGK plug
MSD cap & rotor
MSD coil
cold air intake
K&N filter
new GM alternator
