Going to pull trigger on Audio purchase late next month early sept. need opinions
Old 07-11-2008, 08:44 AM
imnotplutonium's Avatar
Default Going to pull trigger on Audio purchase late next month early sept. need opinions
This is what I am looking to get. I will install myself once I get the wiring diagram etc.
JL Audio A series A1400 400watts
JL Audio PowerWedge CS11ORG-W3v3
MTX RE-Q
StreetWires 4 gauge Amp wiring kit, blue
Tsunami Lite Wave Capacitor 1.2F
JL Audio Bass Remote
Street wires 12 gauge speaker wire, 10ft
Total:$1,027.94
I was looking into JL's new amps and can't really find a big difference for the couple of hundred dollars increase. You guys know why they are better? besides the extra heat-sink.
I also was looking into the powerwedge with 2-W3v3, but from what I have read that would be too much bass, and require a 1000watt rms amp which obviously costs more too.
Opinions?
Looking at the Slash v2 500/1 v2 amp it will put out twice the watts at 4ohm's than the one listed above. Is it worth the extra $200 for another 250watts rms?
JL Audio Slash V2 500x1 monoblock class D amp
I also noticed this had signal-sensing so I don't have to run a remote wire which is nice.
*This is for my G35 with the stock Bose system not Formula* thanks
Old 07-11-2008, 11:45 AM
pentavolvo's Avatar
G35 doesnt need the req
its low level if you tap in before the bose amp. i.e. splice some rca connectors in on the input side of the amp and its full range signal
