How to remove gas cap cover
Old 07-11-2008, 11:03 AM
02BEAST's Avatar
Question How to remove gas cap cover
I need to take my gas cap cover off for the body shop anybody know it comes off?
Old 07-11-2008, 09:54 PM
Craiggg's Avatar
Not really too sure but if the body shop doesn't know how then I dunno if I'd use that body shop.....
Old 07-12-2008, 04:27 AM
ae13291's Avatar
first i think u remove the screws that hold the plastic cover around the gas cap
Old 07-12-2008, 11:16 AM
Copy & Paste Moderator
VIP1's Avatar
Here is a quick write-up on replacing the stock fuel door with a billet 2000-2005 Eclipse fuel door:
https://ls1tech.com/forums/showpost....1&postcount=36
In there it gives an overview of removing the stock fuel door.
Old 07-12-2008, 07:02 PM
bowtieboy10's Avatar
you have to remove the black cover in there first by unscrewing it. then you will have to drill the rivots taht hold the door in there. and simply pull it out. you can either re rivot it back in or you can put some screws in it to hold it. hope that helps. and why isn't the shop removin it for you??
Quick Reply: How to remove gas cap cover
