Centerline???
Old 07-11-2008, 04:40 PM
reaper97's Avatar
Default Centerline???
I need to know will the the centerLine telstars 15 in. x 8 in., 5 x 4.75 in. Bolt Circle, 5.5 in. Fit on an ls1 since the calipers are bigger than lt1's?? Should they fit if I grind them?Spacers?Thanx
Part #135807547
Old 07-11-2008, 11:36 PM
camaro468's Avatar
you will have to grind i was going to buy a set of 15x8 and 15x4 telstars and called centerline they told me i would have to grind the rear and use a spacer in the front they do make a 17x9.5 in the telstar thats what i am going with on my z
Old 07-12-2008, 02:07 AM
JGKadell's Avatar
you have to grind A LOT and they are not that light of a wheel to be worth it if that is what you are going for. They don't weigh much less than a stock wheel. It depends if you just want the look.
Old 07-12-2008, 05:20 PM
reaper97's Avatar
These wheels are light have u actually picked one up? they way nothing
Old 07-12-2008, 05:32 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
What I read by doing a quick search is they require more grinding than a set of Welds
