Drag Racing Tech - Sway bar Question
Merciless
07-11-2008, 05:44 PM
I'm going to disconnect the front stock sway bar for the track. Would it be beneficial for me to upgrade my rear sway bar or should I just leave the stock one in?
Thanks
TheBlurLS1
07-11-2008, 07:37 PM
With the 1" rear Spohn bar, and no front bar, my car handles almost as good as stock (from what I can recall lol).
chrs1313
07-12-2008, 12:05 PM
exact rear sway bar helps me a ton at the track with my launches...
Merciless
07-12-2008, 04:01 PM
any numbers pre and post?
thanks for the info guys :thumb:
chrs1313
07-12-2008, 04:19 PM
helped me about a tenth in the 60 ft...was in the high 1.5 range because i was twisting the rear chassis over and causing the rear tire to lose traction...now well i kinda destroyed the cam only 60ft with my power and weight...with stock gears too...
Chrs1313, is that with the stock 10 bolt?
I'm thinking of getting one.:eyes:
chrs1313
07-12-2008, 07:04 PM
yeah sure is..the rear is 100% stock untouched...u just have to tilt the saddles back a little to get it to clear the rear cover...i got mine for like $150...i do also have a rear air bag in the passenger spring with 40psi
TheBlurLS1
07-14-2008, 05:05 PM
:werd:
The Spohn swaybar mounts are a must with this bar. I had to tilt mine back too, and I've got a Moser 12-bolt with a girdle.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
