Will AIR system removal cause emissions to fail?
According to the new and improved "braile" version of LS1Tech's stickies , it states the following:
Removing the fuse will only stop the pump from running. The computer is still looking for all the other parts to work properly, ie the check valves on the exhaust manifolds.
AIR - Air Injection Recirculation - Emissions controll device. Injects fresh air into the exhaust gas before the cats. Helps them heat up to reach "emissions light off" faster.
Removal Pro's:
Weight, clean bay, no more annoying sound on startup, spare rubber hose to use on other stuff.
Removal Con's:
Only worry about VERY strict visuals (read: California) causing failure. Sniffer test can only tell before car is warmed up. After car reaches operating temp, the AIR pump shuts off and becomes useless. SES light will come on if system is removed unless codes are tuned out. Blockoff plates for exhaust manifolds required unless using "race" headers.
Removal Pro's:
Removal Con's:
it will throw a code if you pull it off, i just did. i had emissions headers so i just hooked hte pump back up and the code went away, now i'll get it tuned out and rip that **** off.
The pump will run a short 2 second test in which it kicks on. Then the PCM looks at the rear O2 voltages to see if they dropped, (adding air in, leans the exhaust out, O2 voltage drops.) If it doesn't see that voltage change then it'll throw the SES light.
