Wet System Real Rich...Safe To Spray
Just wanted to get some insight on this, song story short, had the car tuned with dumps now i have a full true dual setup over the axle......my question is when it was tuned itran a good AFR, high 12's low 13's both N/A and on 125 shot. Put it back on the dyno a couple weekends ago (differant dyno), with nothing changed but the exhaust and some collector leaks.....now my AFR for N/A is 11.1 and whats worse is the 125 shot went below 10.0 AFR, car still put down 473/501, but would it be safe to spray it again or what can I do to lean it up a little to spray safe, i.e. lower fuel jet, higher bottle pressure. The system is a NOS wet plate.
i would get the car retuned, your NA tune is not dead on like it was before. From there you want to jet the fuel to get yourself to apprx. 11.5:1. You could jet from where you are right now to get there, but your NA power will be lacking.
