Fuel pump trouble...
We are just in the process of putting the engine back in my car, hooking up the harness, etc...Went to fire it off today, and its doesn't continuously get fuel. Hotwire kit is hooked up, priming system works, but when you attempt to crank it....nothing. As I said, I know the fuel pump is ok and getting power, because it gets fuel during priming, but nothing after that. Is there a sensor that (if we broke during install) would keep the fuel pump from running?
Thanks,
-Will
Thanks,
-Will
