Question about stock driveshaft with 12-bolts
Hi,
I have Moser 12-bolts .... I want to know if can install the stock drive shaft that it is in my car with this rear end ?? I called moser , they said that I have to change only the U-Joint , but their are 3 kinds of this u-joint , I don't know which one should I get ..... how could I know the exact one ??
what I know that all LS1s has the same drive shaft !!! how their are 3 kinds of U-Joint , because it has to be just one kind !!
thanks in advance
thanks in advance
Re: Question about stock driveshaft with 12-bolts
I dont know the NAPA part number off hand, I think maybe 477?? But I would measure and make sure your stocker will fit. Some have to have the DS shortened...some dont.
#447 is the crossover U-joint that you'll want. It allows you to use the 1310 yoke on the stock driveshaft with the larger 1350 yoke on the Moser. As 96zee mentioned, NAPA should have them.
