I need help connecting headlights
I did a 1993-1997 to 1998-2002 front end conversion (to trans am).
I need help connecting the headlights up?? How to? same with the fog lights? Thank you
Edit to Add: Also how do the Trans Am (1998-2002) front parking lamps attach? There are two holes on each side that I see match up with the bumper, do you use a bolt or a screw or what, and what size??? Also I see one opening is for the light socket to go into, what is the middle hole that has a black rubber piece covering it for??? Thank you
