Code P1415, WTF???
Old 08-22-2003, 08:46 PM
Ferocity02's Avatar
Default Code P1415, WTF???
I finally figured out why the SES light was on. I got the car scanned today and the code was P1415, AIR Pump Circuit Malfunction. The guy said there were two codes for it, and they were the same. The code normally comes on about 30 miles after being resetted. Anyone know what I should do, is this something the dealer needs to fix? Thanks
Old 08-24-2003, 02:34 AM
Ferocity02's Avatar
Default Re: Code P1415, WTF???
I was told it was the driver's side check valve, so I changed it and the light came back on. Anyone know what's going on? Thanks.
Old 08-24-2003, 03:28 PM
ss rally red's Avatar
Simple thing to check is to see if the air pump fuse is blown,sounds like the pump is not coming on.
Old 08-24-2003, 04:26 PM
Ferocity02's Avatar
Nope it's good. The passenger side check valve was bad, not the driver side like the code said, which I'm not suprised because it can't tell the differnce between the two since they are both on the same hose.
Quick Reply: Code P1415, WTF???
