Twin pumps for 99-02 question
I read the sticky, but have a question. I already have a racetronix pump in my 00. MM's sticky talks about cutting out the bucket, but I didn't have to with the racetronix kit. The racetronix pump has the fitting for the factory bucket fill. Will I have to cut the bucket when I add the second pump or will the current pump be able to keep the bucket full? I don't want to cut it out if I don't have to. That's why I bought the racetronix kit to begin with. Thoughts???
We use different pumps then the single kit But the way it is setup there is no need to keep 1/4 tank at all times you can run it fairly low. (Running empty is never a good thing for pumps)
Nate
Nate
Yeah, running it empty is not good, but when I'm changing fuels I like to get it fairly low. I just read that some of the early DYI double pump kits couldn't run lower than a 1/4 tank.
LS1TECH Sponsor
The F99-FPA can not be used with a DP system because of its jet pump feed.
The single in-tank F99-FPA system should not be used with a modified bucket.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
