Tools & Fabrication - Anyone needing a valve spring tool?
Pages : [1] 2
Larry
08-23-2003, 08:02 AM
I am offering an easy to use valve spring install/remove tool. The tool comes with an internal socket head stud for easy of wrenching and a grade 8 nut.
I currently have plenty of tools in stock. (02/02/05)
Unfortunately I have had to increase the shipping cost to $10 so that all tools will go out with tracking. This is resulatant in the number of guys reporting their tool lost in shippiing. Sorry for the additional cost! Total shipped is now $40.00.
Following are pics of the tool and with the tool installed on head.
http://www.mustangmods.com/data/440/valvespringtool.jpg
Email me or PM me for more info. If you wish to order via Paypal my address is larry98@alltel.net.
Approved by Nineball (Tony)
Nine Ball
08-23-2003, 08:34 AM
Nice and simple setup, I like it! And, I also know how specific you are about the tools you use Larry, and how well they work. So, I think I'll need one :D
Gotta move this thread to the tools forum, but I'll leave a pointer in the internal forum.
Tony
StevieZ
08-23-2003, 09:47 AM
I would be in too.
DrkPhx
08-23-2003, 10:35 AM
Count me in. I sent a PM.
Brains
08-23-2003, 12:54 PM
Hey, I like that idea... I have some scrap in the garage, I'm gonna ghetto one up and see how it works.. :D
Pete2k_Z28
08-24-2003, 11:14 AM
Now THAT's a slick tool for our limited-clearance applications!
Larry
08-24-2003, 11:32 AM
Shall I add you to the list? Send me your shipping address.
Pete2k_Z28
08-24-2003, 11:05 PM
<~~~ Former machinist ;)
I was really just commenting on the ingenuity there. It's always the simple, creative solutions that make the most complex jobs easier. Working in machine shops for 9 years gives one an appreation for stuff like that :)
mighty mex
08-25-2003, 01:31 PM
put me down
when and where do i send the m o
Larry
08-25-2003, 02:07 PM
put me down
Email me your full name and shipping address. I don't want money until it's a go. larry98@ev1.net
Larry
08-28-2003, 07:13 AM
We have six commited. We need 14 more!
StevieZ
08-31-2003, 03:47 PM
TTT
Scalpel
08-31-2003, 06:32 PM
I'm in.
Larry
08-31-2003, 07:52 PM
I'm in.
You are in Levi. Send me your full name and address to larry98@ev1.net
We are looking at about 3 weeks now. I have placed the order.
I'll let everybody know by email when to send funds. I will be taking Paypal if you prefer.
chino_man279
09-01-2003, 03:43 PM
sign me up for one of these....
Joe
Smitty
09-02-2003, 04:10 AM
I'm in
Larry
09-02-2003, 07:17 AM
I'm in
I received your email and you are down for one.
2002SS#7339
09-02-2003, 11:40 AM
I'm in. Info sent...
LS1x2
09-03-2003, 09:49 PM
I guess it's not obvious to me how it works. You just screw down that nut to compress the spring? Counldn't you end up breaking that stud?
Larry
09-03-2003, 11:38 PM
The spring will compress long before the stud breaks or the threads fail. The threads and rocker bolt hold the spring load at max rpm and full lift. That's a lot more load than required to just compress the spring enough to get the keepers out.
Z06PSI
09-06-2003, 10:15 AM
I'm in....
sleepersilverado
09-07-2003, 03:45 AM
this is a good tool and easy to use i made my own and it worked awesome.
John02SS
09-08-2003, 04:49 PM
I have a question. The stud screws down in the rocker arm bolt hole and bottoms out then the nut us applied to apply the pressure. Any concern with the stud doing damage to the head at the bottom of the bolt hole? Looks like a great tool! Thanks Larry!
John
Larry
09-08-2003, 04:56 PM
John
I don't know how thick the head is beyond the hole but you don't have to torque the stud in but hand tight. I couldn't imagine torquing the stud so tight it breaks through the head. I did mine and no damage at all.
If you mean pulling the threads out when wrenching the nut then no to that too. The loads at max rpm full valve lift is greater than required to compress the sping just far enough to remove the keepers.
John02SS
09-08-2003, 08:07 PM
When you start cranking on the nut the stud will also tighten in the hole. I guess my question is will the stud stop trying to tighten itself when the bottom is reached or will it dig down as you tighten the nut down on it. Thanks.
Brains
09-08-2003, 09:47 PM
I fabbed one of these up in the garage tonight, and tested it out on a motor sitting on the stand. I'll say this, if you'll ever change valve springs on an LS1, PICK ONE UP !!! Larry's price of $25 is more than worth it, trust me. I wish I had an inch/lb torque wrench to measure the torque needed, because when testing with my regular torque wrench I put it at the minimum 15lb/ft. and it never clicked. I used a regular rocker bolt on mine (can you say ghetto?) and that worked fine. Larry's setup is even better, with the stud.
Larry
09-08-2003, 10:06 PM
Like Brian has said in the previous reply, it takes very little torque on the nut to turn it. A little lub on the bracket/nut/threads will make it turn even easier.
The stud will not "dig down as you tighten". At least it did not for me.
John02SS
09-09-2003, 08:53 PM
That is what I needed! Thanks Larry and Brian! I may try to fab one up, but will probably just pick up one of Larrys. Being the tight wade I am though I gotta try first! :D
v8maro
09-10-2003, 09:32 AM
How long would it take you to get one of these to me? I need one ASAP so i can get my car going again, this would save me $150 in labor at a shop.
Maybe you can rush one out to me?
thanks
-Steve
Larry
09-10-2003, 09:40 AM
thanks
-Steve
I have the one I used on my engine that I could send you. The stud is 1/4" shorter than the one I will be supplying with the new batch but it worked with my 26918 springs.
The new batch should be ready to ship next week.
humanoidZ06
09-10-2003, 12:33 PM
Has anyone tried with with double springs, such as REV or the new Crane springs?
Dave Carney
09-10-2003, 03:46 PM
I will on Tuesday, i made mine at home, same design
sleepersilverado
09-10-2003, 05:58 PM
humanoid i have used one i made on the dual rev springs this last weekend 9/6. i had a broke spring and i used the tool and it worked fine. the difference in the one i made is that i used a longer metric bolt that i got from home depot instead of a stud. once you get in a groove it does not take long at all to change all the springs especialy with air tools.
Larry
09-12-2003, 08:43 AM
Using a bolt can be a dangerous situation. If you start applying load before you have enough thread engagement the threads could strip in the head. I haven't seen many bolts with enough threads to have enough thread to engage and then travel far enough to install the keepers. Particularly when installing a tall free length spring. Remember you are screwing into aluminum.
Krab
09-14-2003, 03:15 PM
It will work with a longer bolt, I did it. I made one of these tools for my cam/spring swap and bought a bolt about 3 inches long, and also bought a nut/washer for it. You just turn the nut all the way to the top of the bolt head with the washer under the nut, then tighten the bolt in the rocker hole, and tighten the nut down to compress the spring. That way if you're worried about turning the bolt while you turn the nut, you can just use a ratchet/wrench to hold the bolt head while you turn the nut. It's a little more work, but I couldn't find any studs in the amount of time I had. Tool worked great, finished all 16 springs in about 4 1/2 hours. :D
Larry
09-15-2003, 01:57 PM
Tools are ready to go out. First batch will ship today. I'm supplying a 5/32" socket head stud. This will make things go a lot faster.
http://www.mustangmods.com/data/440/valvesprgtl.jpg
Let me know if any of you have any problems or need help.
apexman
09-15-2003, 03:43 PM
I just bought a T1 cam and will be needing an install tool and this sounds like an ideal tool for my garage. I will send you an email Larry.
Derek
Larry
09-19-2003, 01:46 PM
Of the 23 people that agreed to buy the tool when they were manufactured, I have only heard from 13 so far.
Would like to hear from the 10 of you that committed to buying the tool and have not contacted me. Please let me know if you still want it?
Dave Carney
09-20-2003, 09:37 PM
I made one of these and used it on a full set of crane doubles. Works GREAT! Couldn't be any easier. I made my stud out of 8mm threaded rod (pretty soft stuff) and the stud made it through all 16 springs although I'll need to cut a new one for next time. Whatever Larry is supplying is probably much better.
Nine Ball
09-21-2003, 03:47 AM
This thing looks great, top quality in person. Thanks Larry for setting this up, it will be a permanent addition to my LS1 toolbox. I'm sure I'll use it many times :D
Tony
Larry
09-21-2003, 06:45 AM
The stud I'm supplying is strong and hard like an Allen bolt. It should last for many spring replacements as long as a touch of lubricant is used on the threads. The threads and nut mating surface on the tool should be lubricated. My stud also has a socket head so wrenching it into the head is a snap.
Glad the one you made worked out so well. Hopefully mine will work as well!
Thanks Tony. I think you will find it is a little better quality than the average can make in his garage.
Nine Ball
09-21-2003, 08:13 AM
For the cheap price and quality of this kit, I wouldn't even waste my time trying to make one in the garage. lol
DrkPhx
09-21-2003, 09:09 AM
I agree. I don't have the tools to fabricate one, so I got Larry's. For anyone who has changed springs on a LS1 F-body, this simple but effective tool is worth it's weight in gold.
Dave Carney
09-21-2003, 10:38 AM
Yeah that's fine if you didn't need it last week! ;) 20 seconds with the cutting torch, 30 seconds with the grinder, and a minute at the drill press....viola.... :chug:
What I can't figure is all these guys using tools where you have to maintain leverage on a ratchet while you fumble with the valve locks, etc.... you almost want to put them out of their misery! :D
Z06PSI
10-04-2003, 09:01 AM
Got mine Larry and it looks like a quality piece and cant wait to use it.....
Larry
10-08-2003, 06:55 AM
Great! Hope it works well for you.
Anybody used theirs yet?
Slowhawk
10-14-2003, 10:25 PM
This is well worth it for anyone looking at this.I made 2 a while ago.1 that fit 918's tight and 1 for duals.I use a 2 1/2 long bolt and have used it on many cars without any thread damage.They work excellent on single or dual springs.Now it takes me less than 1.5 hours to do springs.
Only other thing you should add to this kit is a hose that screws into the plug hole so you can pump the cylinder up.Now that would be a complete spring changing kit.
(I use a compression checker hose with the valve removed)
John02SS
10-20-2003, 11:09 PM
With the recent rash of broken bolts in the head I ask how strong the stud is. I've read few post about the rocker bolt breaking due to it side loading as it compress's the spring along with water pump bolts. How much strong/better is the provided stud. Thanks for the info Larry!
John
H82BBad
10-20-2003, 11:23 PM
looks like a great tool.
I would use a bolt with a nut on it and hold the bolt with one wrent and turn the nut, this way you get all the threads in the hole and no concern about bottoming it out in the head
Larry
10-21-2003, 07:42 AM
The stud I supply has a very high tensil strength. It's an Allen bolt. They are very strong. As long a you run the stud down all the way into the head threads before attempting to remove the spring you won't have a problem.
Has anybody had a problem with the stud I supply? I have shipped out quite a few now and have not heard of any problems.
Scalpel
10-21-2003, 03:57 PM
Larry, I sent a check a few weeks ago? Did it arrive? If not I'll cancel the check and paypal you the $$
Larry
10-22-2003, 11:37 AM
Levi,
I emailed you.
Larry
10-25-2003, 08:56 AM
All tools are sold. If we can get together a half dozen or so I will place another order.
Thanks!
pewter99SS
10-25-2003, 04:36 PM
Larry I PM'd ya, I want one if you get another run going.
Larry
10-25-2003, 08:41 PM
I'll put you on the list for another run. You are the first so far.
pewter99SS
10-26-2003, 01:47 AM
thanks, have you tried posting this on LS1.com also?
John02SS
10-26-2003, 11:17 AM
I got the last one! Thanks Larry! I'll post feedback after I install a set of 918's with it.
John
VortechC5
10-27-2003, 06:58 AM
I'll take one. Let me know when/where to PayPal.
Larry
10-27-2003, 07:04 AM
I'll put you on the list for the next batch.
Damian
10-31-2003, 07:03 AM
Larry sorry if I missed this, but does this tool work with dual springs?
Larry
10-31-2003, 07:13 AM
This tool should work with any set of springs.
Ramair346
10-31-2003, 03:38 PM
I have one and I've used it 2X. This thing is AWESOME for taking ANY spring off. Duals, singles, it doesn't matter. It was easier to put single springs back on vs. double, but I may not have had it perfectly aligned. It makes the back 4 cylinders on an F-body a breeze! Well worth $25. The only upgrade I would advise getting is a better nut. When using this tool to remove double springs, it seemed that the nut was a little soft so a trip to home depot solved the problem. Otherwise an awesome tool!
Larry
10-31-2003, 06:25 PM
Ramair346,
Thanks for bringing the nut problem to my attention. The nuts supplied were grade 5. I will supply grade 8 the next go around. Even with grade 8 the threads will need lubricant for longevity.
ALPINE
11-01-2003, 02:04 PM
Put me down for one please.
93TAWicked1
11-01-2003, 07:14 PM
I'm in as well let me know when they are ready I'll email you too! Thanks,
Bobby
Larry
11-01-2003, 11:46 PM
Bobby
Please send my your email address and shipping address.
Thanks,
Larry
Larry
11-06-2003, 07:37 PM
I have a second batch of valve spring tools available.
Same price, $25 plus $5 shipping.
I can accept Paypal. larry98@ev1.net
Scalpel
11-07-2003, 03:52 PM
send me the invoice again, larry! lprocter@hotmail.com
JoeDirt
11-08-2003, 12:55 PM
You have pm !! :)
Ramair346
11-08-2003, 03:07 PM
I'm almost tempted to grab another one because this thing works so well. It's great to see someone finally sack up and bring a high quality reasonably priced tool to this platform.
Larry
11-08-2003, 03:38 PM
Thanks for the compliment!
Joe,
I sent you an email.
John02SS
11-09-2003, 08:45 AM
Worked GREAT! Thanks for the great product Larry! Took 2 hours taking breaks and watching football games! :D
Scalpel
11-09-2003, 10:38 AM
Just ordered mine! It should make swapping the G5X-2 in my bro's 00 WS6 a cinch. Will provide feedback after using it.
onyxxtreme
11-10-2003, 01:03 AM
i think ill order one next paycheck
Richie Carbone
11-10-2003, 03:44 PM
Thanks Larry! I got mine today. It's alot better quality than the tools that come with the Kent Moore LS1 tool kit! :judge:
You da man!
Larry
11-10-2003, 08:13 PM
You da man!
They got it to you pretty quick. I shipped it Friday.
Thanks! I'm glad you like the quality. I know you will like the way it works!
Scalpel
11-13-2003, 03:45 PM
I got mine today, it's kick ass!
My only suggestion is to round of the the corners at the back of it. It'd make it cooler looking :D
Larry
11-13-2003, 03:59 PM
We sure want your tool to look "cool". Send that baby back with a $50 bill and I'll round it off for you! LOL!
Glad you got it Levi. Let me know if you have any problems.
Scalpel
11-13-2003, 05:07 PM
Thanks, Larry! ;) You should offer them in powdercoated colors to match the cars ;) LOL
Greg_E
11-20-2003, 08:03 PM
Looks like I got to the party late. :bang: When will you have more of these ready? I'll take one if you can get it to me in three weeks or less.
Larry
11-20-2003, 08:24 PM
I have them available right now. Still $25 plus $5 shipping. I can take Paypal.
Thanks,
Larry
Bink
11-20-2003, 08:48 PM
Thanks,
Larry
Cool. Where do we sign up / paypal?? Thanks!!
joel
Larry
11-20-2003, 09:00 PM
www.paypal.com
Bink
11-21-2003, 12:01 AM
www.paypal.com
DUH - sorry :emb: . I meant where do I send the money to (email add), i have a PayPal acct (friggen Ebay!). Shit!....Nevermind I see it in the Thread :thinker:
joel
2002SilverWS-6
11-21-2003, 12:06 AM
Looks good. How long is the wait for one?
93TAWicked1
11-21-2003, 12:26 AM
I got mine today took like 3 days after payment!
Greg_E
11-21-2003, 04:57 AM
www.paypal.com
Larry,
I tried to use Paypal this morning and the site is down right now. Please hold one of these for me and I'll send the money when I get home from work this evening.
Thanks
dragonZ28
11-25-2003, 12:41 AM
I've become a master with this tool. It will swap out any springs whether they are single or duals. With a stubby ratchet, this job can be done in a few hours. It is not impossible to lose a couple of valve locks in the process though. I did the swap on my 99 Z28 and lost 3. This was my first swap. I swapped them out again on my car and lost none. Then I did a swapp on a 00 WS6 and lost none. I guess it comes with practice. I used the TDC method everytime with hand tools.
One suggestion though. Shorten the legs of the tool so that when the spring is compressed, it is compressed more evenly instead of putting all of the pressure on the outside of the spring. Great idea Larry. Come up with some more genius LS1 tools.
Larry
11-25-2003, 01:56 PM
dragonZ28,
Glad you like the tool. I used a pencil magnet when I compressed the spring to help prevent losing the keepers.
I'll take a look into shorter legs. Really didn't notice any angular rotation of the retainer with my 918 springs. If it was there it was not a problem.
dragonZ28
11-25-2003, 02:20 PM
No problem Larry. I too used a magnet tool, and it helped out alot. The tool is great, but has the capability to be greater with shorter legs. This will relocate the tips of the legs around the center of the retainer more, and makes for even easier spring removal. If you have any more, shoot me a PM. I'm interested in purchasing one of my own. I used a friends and I want one.
A good trick to remeber with this tool is to slip the tip of the magnet down the retainer, and connect to the valve and pull it up while you compress the spring. It makes the TDC method work very quickly with little trouble. Plus it helps locate where the spring needs to be centered at for the valve to come through the retainer perfectly without rubbing the edge of hole in the retainer. I give you alot of credit. Very simple, but very effective.
Larry
11-25-2003, 04:41 PM
dragonZ28,
Yes I do have several more left if you want one.
Billnz28
12-12-2003, 10:18 AM
ill take one if you still have them. let me know
CAT3
12-12-2003, 06:44 PM
Larry, sorry I didnt need to use it earlier, but used the VS tool you sent me 3 months ago, it is the chit man. That puppy pulled the double springs of my buddies PP heads so quick and easy. I swear. I was pissed cause it took me longer to start the air line than it did R&R the spring.
Thank,
Charlie
jmX
12-12-2003, 07:01 PM
Has anybody had the stud break yet? I know it was a problem with the autozone version of this tool, but it used a bolt rather than a stud. A stud might just totally eliminate the problem!
Mike K.
12-14-2003, 01:01 AM
Any more of these left?
Larry
12-15-2003, 11:56 AM
Yes, I do have more left.
Billnz28,
I PM'ed you.
Mike K.
12-15-2003, 03:25 PM
cool i will order one asap
Billnz28
12-15-2003, 05:55 PM
payment sent ,thanks Larry
Ferocity02
12-15-2003, 10:41 PM
Larry, I need one!!! Sent ya an e-mail!!! If you don't get it then send me one.
Thanks! :)
Mike K.
12-15-2003, 11:54 PM
payment and email sent Larry. Thanks.
ScottyG
12-16-2003, 09:39 AM
Larry, I need another one. It'll be a Christmas present for one of my LS1 pals.
I'll get a $30.00 PayPal headed your way ASAP.
Thanks,
Scott Garvie
killer01ws6
12-16-2003, 03:50 PM
Larry still have any?
If so please send me a paypal bill to
Engineertelco@yahoo.com
Thanks,
Pete
Larry
12-16-2003, 04:05 PM
Yes, I have a few left. larry98@ev1.net
BTL FED
12-16-2003, 04:49 PM
Just sent paypal funds, thanks larry
killer01ws6
12-17-2003, 07:18 AM
Payment Sent :)
Larry
12-17-2003, 07:43 AM
Thanks Charlie (CAT3). Glad it worked well for you.
Pete, I received your payment. Your tool will go out today.
Thanks to all!
Mike K.
12-17-2003, 05:00 PM
Got your pm as well Larry, cant wait till it gets here, seems like an awesome tool.
Ferocity02
12-24-2003, 09:38 PM
Got mine today. Very neat little tool. Thanks a lot Larry!!!
jmX
12-25-2003, 07:10 AM
RaNsOm
01-04-2004, 02:30 PM
anymore left larry? Im gonna be putting in my cam and 918's shortly...I'd love to pick up one.
Larry
01-04-2004, 04:10 PM
I should have more soon. I'll post when I get them.
RaNsOm
01-04-2004, 11:40 PM
I should have more soon. I'll post when I get them. great, thanks :) Just as long as its before March, lol.
Hardtop00SS
01-06-2004, 07:36 PM
I will take one also, emailed you.
Larry
01-06-2004, 07:44 PM
Got your email. I have you down. Thanks!
menikmati
01-07-2004, 01:13 AM
got mine yesterday, quality of product and service was top notch
RaNsOm
01-07-2004, 11:59 AM
Cant wait to get mine :)
Damian
01-09-2004, 01:48 AM
Larry got any more? I am ready to order one!
Larry
01-09-2004, 07:40 AM
Not right now but hopefully in a couple weeks. Send me you email address and I'll let you know when I have them. Thanks!
RaNsOm
01-10-2004, 05:31 PM
btw larry, my email is webmaster@the-sanitarium.net, email me when you get some also.
Larry
01-10-2004, 08:20 PM
I have you down for a tool.
melbourne_ls1
01-12-2004, 11:01 PM
Put me down for one, I sent you email.
Thanks.
Larry
01-13-2004, 06:41 AM
melbourne_ls1,
I have you down for one.
1LEThumper
01-13-2004, 04:40 PM
ya got mail :)
Larry
01-13-2004, 05:55 PM
I've got you down for one Anthony. I'll let you know when they are ready.
bryan c
01-14-2004, 08:16 AM
i want one, sent you an email.
Larry
01-14-2004, 08:25 AM
I have you down for a tool Bryan.
The shop is behind a little. Looks like my original two weeks is going to be three weeks. Hopefully soon though.
Anybody wanting one just send me your email address and I'll shoot you a reply when they are here. Thanks!
jmX
01-16-2004, 07:33 PM
Is this question really that hard to answer?
Scalpel
01-16-2004, 10:52 PM
Mine has never broken the stud. Used 5 times now. Larry uses a very high tensile strength stud.
Larry
01-17-2004, 06:58 AM
If anyone breaks a stud I sure would like to know about it.
If you keep a small amount of lube on the threads you should be able to use it on many springs. Also lube the tool after use to prevent rusting.
I should have a good supply of tools in next week.
Damian
01-18-2004, 05:15 PM
Any news Larry? I need one soon.....
Larry
01-18-2004, 05:53 PM
Hopefully I should have more this week.
jmX
01-21-2004, 01:04 AM
That is excellent to hear!
Larry
01-22-2004, 12:56 PM
I have tools in stock now for anyone else needing one. I have emailed everybody that had requested a tool.
If you like you can make payment via Paypal of $30 which includes shipping to 48 states at larry98@alltel.net
ChevyNo1
01-24-2004, 10:56 AM
I want one! What do you need from me ( besides money ;) )?
- Dug
ruquik
01-24-2004, 10:58 AM
Send Me Some Info On A Address To Send Money To.
What Is The Stud Made Out Of, Just Wondering If It Can Take The Pressure Needed To Compress The Springs Time After Time??
Looks Very Nice Compared To The More Performance Tool.
Thanks
Roger
Larry
01-24-2004, 11:11 AM
- Dug
$30 and two pints of blood will do it! LOL!
You can make payment to my email address at larry98@alltel.net or send payment to Larry Sample, 4302 Tarlton Way, Sugar Land, TX 77478
Thanks!
Larry
01-24-2004, 11:27 AM
Thanks
Roger
The information I have says the studs are made of allow steel and heat treated to RHNC 48-53. The alloy contains Chromium, nickel, molybedenum and vanadium of suffiecient quantity to assure that the specified strength properties are met after oil quenching and tempering. It will take a lot more pressure than the springs exert! The nut supplied is a grade 8 nut.
If you maintain lube while wrenching it should last for more spring changes than the average will ever perform. It will take a lot more pressure than the springs exert!
My previous reply has both my email and home addresses.
ChevyNo1
01-24-2004, 12:39 PM
Thanks Larry! Just sent you a PayPal.
- Dug
Larry
01-24-2004, 12:50 PM
- Dug
Your email doesn't seem to be working but I did received your payment. Your tool will go out Monday.
ChevyNo1
01-24-2004, 02:51 PM
Thanks Larry!!
BLO BY U - TA
01-24-2004, 04:20 PM
Larry,
I can't believe that i have just seen this post, duh....
If you can send me the info that i need to send you, I can paypal the money to you! E-mail me and i'll send you my address!
Blo-byu@sc.rr.com
Alan
PurdueWS6
01-24-2004, 07:55 PM
Hi Larry!
Sent you a payment on paypal !
Mahmood
NaSSty99
01-25-2004, 06:04 AM
larry, sent you an email
Hardtop00SS
01-25-2004, 04:10 PM
My buddy and I used this tool today to do my springs today on my 00 SS. My buddy used the valvespring tool from thunder racing on his 99 SS. He said that this tool works 100 times better then the thunder racing tool.
I HIGHLY, HIGHLY recommend this tool!
Thanks Larry!
Robbie
ruquik
01-25-2004, 08:51 PM
thanks for the info larry
i will send money out sometime this week
roger
skydog
01-26-2004, 10:07 AM
Mine is on the way!!!
Thank you Larry you are VERY easy to deal with!!!!!!!!!!!!!!!!!!!!
Skydog (Matt)
Larry
01-26-2004, 11:34 AM
Thanks to everybody for all the kind words and orders!
All tools are on the way to everyone that has ordered. Hopefully all questions have been answered. Let know know if anybody has any problems.
Steve98Z
01-26-2004, 01:42 PM
Larry I sent paypal last night, do you think it will make it here by Friday?
Larry
01-27-2004, 06:53 AM
Larry I sent paypal last night, do you think it will make it here by Friday?I would think you would have it by Wednesday. We are both in Texas. Let me know if you don't receive it.
Ken G
01-31-2004, 11:56 AM
I just used Larry's tool today for the first time and it turned a job I HATE and DREAD into one that was FUN. I've done 3 other spring swaps on this car using the SLP tool and the More tool and the difference is amazing. Thanks Larry! :cheers:
Scalpel
01-31-2004, 12:11 PM
Yep, Larry's tool is by far the best.
IrateTA
01-31-2004, 11:51 PM
Hey Larry, is there any chance I can order one of these? Or do I have to wait for another 20 people to sign up? You can put me down for one, I am 100% sure. I'll try to get an e-mail out to you...
I was reading through some cam install threads and was a little put off by the crappiness of the Moore tool...
Damian
02-01-2004, 03:28 AM
Larry, i'm sending payment Monday evening via next-day Fedex unless you say otherwise. Please let me know, thanks
josh
Larry
02-01-2004, 07:54 AM
Thanks as always guys for the compliments. Glad the tool is working out for you!
Rob (IrateTA),
I have plenty in stock. No waiting anymore for 20 to sign up.
Josh (Damian),
Fedex is fine. $30 total including shipping. If it gets here early enough I can get it out the day I receive it.
IrateTA
02-01-2004, 12:05 PM
Rob (IrateTA),
Josh (Damian),
Great - sent you an e-mail.
skydog
02-01-2004, 09:42 PM
Got tool today!! Looks great!!
THANK YOU Skydog (Matt) :hail:
JodyJ
02-02-2004, 12:15 AM
I'm in. I sent you my info.
Thanks,
Jody J.
Damian
02-02-2004, 01:14 AM
You WILL have a check for 30 bucks from me on Tuesday. Try to stick around the house cuz they will require your signature. Thanks
josh
Larry
02-02-2004, 07:16 AM
Anyone requiring faster delivery than standard metered mail can calculate cost by going to http://wwwapps.ups.com/calTimeCost?loc=en_US Enter destination zip code 77478, check whether going to a business or residential, then click Retail location and Your packaging.
Josh,
I should be around but I do have a couple errands to run tomorrow.
Steve98Z
02-02-2004, 08:26 AM
Larry I used your tool this weekend, works great even in the tight spots, thanks again.............
Steve
Scalpel
02-02-2004, 09:17 AM
Larry you need to advertise these on Ebay and the Corvetteforum.com You'll sell hundreds more.
Larry
02-02-2004, 09:21 AM
Thanks Levi, I hadn't thought about the Corvette forum. I have sold a couple on Ebay.
Scalpel
02-02-2004, 09:43 AM
Corvetteforum, LS1.com, KyFbodies.org, ZO6vette.com, ;)
JodyJ
02-02-2004, 10:15 AM
Do you have any left?
Larry
02-02-2004, 03:02 PM
Jody, your tool went out today...
corvette184
02-02-2004, 08:14 PM
you have paypal.......i already have the moore tool...but i will use both and see if one is eaisier than the other.....i really appreciate a nice and simple tool......looks like you have a winner :D
Monka
02-02-2004, 09:57 PM
Can you e-mail me at viper2554@mindspring.com with more info on ordering the tool from you. Thanks
redaddiction
02-02-2004, 11:29 PM
runamuk
02-03-2004, 09:40 AM
I'd like to buy one of these can you send me an E-mail with payment info. rjgroth@aol.com
Larry
02-03-2004, 10:02 AM
Everybody should have an email that requested information. Thanks...
J.R.
02-03-2004, 01:57 PM
I'm in !
99Z51R
02-04-2004, 06:40 PM
Larry, Just saw this tool, and sent you paypal.
Thanks- Eric
GREGGO
02-05-2004, 03:51 PM
Larry, put me down for one. I sent you a PM with the email addy.
Larry
02-05-2004, 06:53 PM
All that have ordered have tools on the way!
tuckerwilliam
02-06-2004, 03:53 PM
Man, this is one cool tool. I haven't got to use mine yet, due to springs not here yet, but it is one well crafted and heavy tool!!
THANKS LARRY YOU DA'MAN!!!!
Mike K.
02-06-2004, 05:30 PM
I just used my tool for the first time today and it worked very well. Thanks for the tool Larry!
Larry
02-06-2004, 07:57 PM
Glad the tools are working for everybody. Thanks as always!
corvette184
02-06-2004, 09:53 PM
got mine in the mail today.....thanks...
98SS Blackattack
02-07-2004, 12:34 AM
Hey Larry do you take MO's? If so shoot me a PM with the price and address.
Thanks Tony
SVC707
02-07-2004, 10:03 AM
sent you pm... if you have any available
Larry
02-09-2004, 12:16 PM
Yes, I have a good supply in stock...
DrHoho02
02-09-2004, 03:42 PM
Larry
I sent u PAYPAL. Look forward to it.
Thanks
Bob
haole_boySS
02-13-2004, 07:38 AM
What do I have to do to get this tool? Actually I need 2 of them. Let me know by email. andy4416@aol.com
Thanks,
Andy
Mike94ZLT1
02-13-2004, 05:10 PM
Hey Larry, very interested in one! Please email me at Mike94ZLT1@yahoo.com, and let me know what I need to do to get one! I have paypal and can send it out ASAP! Thanks!
BriGuy
02-14-2004, 03:29 PM
Larry you have mail.
TnTrk53
02-15-2004, 09:42 AM
Larry, you have more mail
01firechicken
02-15-2004, 06:06 PM
Larry, you have even more mail
Larry
02-16-2004, 07:17 PM
Sorry I have not reponded yet but I just got back from out of town. (Monday night) I'll get to everybody by morning.
I have plenty of tools in stock so go ahead and send payment of you like to my Paypal address larry98@alltel.net
Thanks...
01firechicken
02-17-2004, 06:45 AM
Thanks LARRY!!!!!!!!! Your the MAN!!
RedHardSupra
02-17-2004, 11:21 PM
if this is the tool that will work on rev duals, then i'm in
Larry
02-18-2004, 06:48 AM
Sure will! I don't know of any spring brand that it won't work on.
RedHardSupra
02-18-2004, 10:44 PM
i'm just asking, because i heard the dual springs can be tricky to do with the more 'traditional' tools. so how do i 'officially' sign up for this deal?
Larry
02-19-2004, 08:22 AM
You can Paypal me at larry98@alltel.net Total is $30 including shipping. Or you can send payment to my house.
Larry Sample
4302 Tarlton Way
RedHardSupra
02-19-2004, 03:09 PM
you've got paypal ;)
RJF
02-22-2004, 02:02 AM
you have anymore of theses? please pm if you do and ill get paypal out to you
Johnny5
02-22-2004, 08:00 PM
I just hit you with paypal.. :D
Larry
02-23-2004, 02:13 PM
It's on the way to you. Along with everyone else that has ordered. Thanks!
jimmy 2 Times
02-25-2004, 12:26 PM
Larry,
do you still have some available?
if so what is your pay pal
jimmy
Larry
02-25-2004, 01:36 PM
Due to the number of tools being lost I am going to have to ship by UPS tracking. Unfortunately the shipping cost will go up to $10.00.
Sorry for the additional cost but too many have reported that they have not received their tools shipping via UPS metered mail.
Larry
02-25-2004, 01:37 PM
Larry,
jimmy
Yes, I have plenty in stock.
As I just posted it will have to go with tracking. Total shipped is $35. Thanks! Paypal address is larry98@alltel.net
BLO BY U - TA
02-25-2004, 01:51 PM
The post office sucks when ever its not letter sized mail. Hell, the price of stamps are rediculous, but what can you do, not like you can vote on it!! Thats another topic!
I always use/prefer UPS or the USPS any day!
Thanks for the great tool again.
Alan
01firechicken
02-25-2004, 02:13 PM
Larry,
Got my tool thru USPS today in Germany. THANK YOU!!!!!!!! Looks GREAT!!!!
Larry
02-25-2004, 02:36 PM
Larry,
Glad you received it. I can get one all the way to Germany but can't get one across town without it getting lost. Thanks!
jimmy 2 Times
02-25-2004, 08:41 PM
just ordered mine tonite
cant wait to get it
thanks
Larry
02-26-2004, 06:49 AM
cant wait to get it
thanks
Itwill be on the way to you today!
RedHardSupra
02-26-2004, 10:08 PM
I got mine yesterday, it's a plate, nut and a bolt, right?
I have no idea how that's gonna be helpful, as I am a mechanical retard, but we'll see.
I got it quickly, and it was well packaged, so thank you so far!
Larry
02-27-2004, 07:00 AM
Sounds like you received the correct parts. Here's that pic again of the tool installing on my head: http://www.mustangmods.com/data/440/valvespringtool.jpg
JayStew
02-29-2004, 06:48 PM
As soon as I figure out what's wrong with my pay pal, I want one too!
Larry
02-29-2004, 07:40 PM
If you like send me your email address and I'll send you a request for payment via Paypal. Maybe that will work?
BriGuy
03-03-2004, 01:59 AM
Larry payment has been sent for a second one. There is a different address for the second one though so please pay close attention to that.
Thank you!! :D
Larry
03-03-2004, 07:25 AM
Thank you!! :DI'll send to the address on the Paypal payment notice. Thanks!
Pro Stock John
03-03-2004, 02:09 PM
Just got mine, kickass!!!!
BriGuy
03-03-2004, 06:34 PM
Larry yes the address on the pay pal is the correct one to send it to, thanks!!!
And we received the first one today, and it looks like a good piece of quality work! :)
JayStew
03-03-2004, 06:55 PM
Pay Pal sent!
horist
03-09-2004, 02:49 PM
Hey... think this would work on a 3800 series motor as well ? (Specifically grand prix)
JayStew
03-11-2004, 05:32 PM
Got mine. Nice piece. Thanks!
BriGuy
03-12-2004, 12:13 AM
Just received my second one, thanks again Larry!
2001zz
03-12-2004, 07:56 PM
if i paypal you tonight when will one be in my hands?
Larry
03-12-2004, 09:19 PM
I can ship it on Monday any means you like. My $10 includes ground shipping and tracking. Depending on where you are located it might take up to 5 days to get it to you.
You can go to www.ups.com and determine how much faster service would be and/or how much it would cost. Use UPS Store and 1 pound weight.
99greenZ28
03-13-2004, 07:06 PM
Looks like a great tool! I'm about to put in a Hotcam in a few weeks and this tool will save me alot of money so i dont have to buy that MORE valvespring tool!
Larry
03-24-2004, 11:15 AM
Still plenty in stock. You can Paypal to larry98@alltel.net Total is $35 delivered with tracking and insurance.
Unstang
04-05-2004, 12:30 PM
PM & paypal sent. I hope you still have some!
Larry
04-06-2004, 08:30 AM
It's on the way to you. Still have plenty in stock.
WAHUSKER
04-07-2004, 07:01 PM
Larry,
Paypal $ sent.
Mark
Wire Dog
04-10-2004, 08:41 AM
Paypal sent.
Thanks Larry
JxxxOxxxE
04-17-2004, 04:00 AM
I am thinking about getting one of these. I think I need to do a few swaps for some guys in my area. When using it, is it recommended to leave the rocker pedastal in like in the picture? I notice that some other rockers are still on, but does it matter...Thanks
I take you you have these ready to ship out?
Larry
04-17-2004, 06:49 AM
I do have the tools ready to ship.
The tool does not interfer with the pedestal. Makes no difference whether it is in or not.
Damian
04-19-2004, 02:29 PM
Larry, how do these work for reinstalling the springs? I can see them being usefull for compressing an already installed spring, but how would they work with putting on a new spring that isn't compressed yet? TIA
Larry
04-19-2004, 08:00 PM
Larry, how do these work for reinstalling the springs? I can see them being usefull for compressing an already installed spring, but how would they work with putting on a new spring that isn't compressed yet? TIAIt removes and installed our valve springs. You do have to pressure up the cylinder or use the TDC method to keep the valve up to release and install the keepers.
KinKornKarn
05-04-2004, 12:53 AM
how do i order one of these...i'm doing a cam install within the next week
Larry
05-04-2004, 06:36 AM
I have four left. After these four are sold I will need confirmed orders of 20 before I can offer anymore. This is due to the declining number of orders I have received lately.
You can Paypal me at larry98@alltel.net to get one of the last four. Total is $35 delivered. Thanks...
KinKornKarn
05-05-2004, 04:46 AM
I don't have paypal...do you take personal checks? I don't care if you have to wait for it to clear.
Larry
05-05-2004, 06:40 AM
I don't have paypal...do you take personal checks? I don't care if you have to wait for it to clear.Yes...but keep in mind if I am out you would go on a waiting list until I have 20 confirmed orders. Best to set up a Paypal account.
KinKornKarn
05-05-2004, 06:29 PM
i really don't have a way of setting up a paypal account...i don't have a credit card...could you pm me who i need to make the check and stuff out too?
Larry
05-12-2004, 03:21 PM
I am out of tools. I will need confirmed orders for 20 before making or stocking more. Sorry but due to slow sales I cannot stock tools any longer. Send me your email address. I'll add you to my list and let you know when I have 20 confirmed orders. larry98@alltel.net
AllCammedUp
05-20-2004, 08:41 PM
E-mail sent - I'd like to be put on the waiting list. Thanks.
HavATampa
07-21-2004, 07:18 PM
E-mail sent.
Larry
07-21-2004, 08:28 PM
Sorry guys but since my last post on May 12th I have only received about 5 committed orders. Doesn't look like I will be able to make more. I do appreciate all who did order and hope they are working good for you.
AllCammedUp
07-22-2004, 06:56 AM
Larry,
Is there any way for you to do a small run for us? Even if the tool costed a bit more, I'm sure others would understand. I'd just like to have the opportunity to purchase it. Thanks!
Larry
07-22-2004, 08:44 AM
Larry,
I can make you one for $50 plus $12 shipping.
ss rally red
07-22-2004, 08:48 AM
I sent you a email awhile back and would buy one at this price also. Ken
44mag
07-22-2004, 11:54 PM
Im Intrested How About $45 Shipped! Pm Me I Will Pay Now! Or Put Me Down For A Future Gp! Thanks!
Larry
07-23-2004, 01:13 PM
I'll have 10 tools available in less than two weeks. Price will be $30 plus $10 shipping.
Those that send a Paypal payment now will be first in line. larry98@alltel.net
AllCammedUp
07-24-2004, 08:08 AM
Paypal sent. Thanks!
Larry
08-05-2004, 08:32 AM
All back ordered tools were shipped on 8/4/04.
I have three more in stock for anyone needing one. $30 plus $10 shipping.
chris2000ss
08-05-2004, 11:23 AM
I'll take one of those tools!!!sent ya an e-mail...
chris
Larry
08-05-2004, 01:59 PM
chrisI received you email. My Paypal address is larry98@alltel.net
chris2000ss
08-05-2004, 10:22 PM
paypal sent..
thanks
chris
89FormulaLS2
08-05-2004, 11:55 PM
I have three more in stock for anyone needing one. $30 plus $10 shipping.Do you still have any of these? If so, set one aside for me and let me know, and I will Paypal you the funds on Friday.
Adam
Larry
08-06-2004, 07:05 AM
Adam
Sorry but all tools are sold...
