84 GEN III swap-Manual to auto brake pedal swap
Swapping manual pedal assembly to an auto assembly but keeping manual brakes. Have an auto pedal assembly. I know the master cylinder actuator rod mount needs to be moved to work for the manual brakes. My problem is that no one sells the pivot mount and Chevy said its discontinued. I cant remove the old one, drill a new hole and remount b/c the factory mount is pressed in and cannot be removed w/o destroying it. WTF??? Any ideas other than just cutting and re-welding the two pedal to make what I need?
