Finally bolted up my bmr tq arm
Had this sitting around for awhile finally decided to install it. I also got a rodded UMI PHB coming to replace my poly one from spohn.
Got a few questions for BMR or whoever.
The bolts that connect the plate on the rear to the tq arm what do those get torqued to. Also do you need to have those loose when you adjust the pinion angle?
LS1Tech Premium Sponsor
Spdfrk, thanks for your business. Torque the bolts that attach the torque arm to the rear to 100Ft lbs. Make sure that you have them tightened down before you adjust pinion angle. If you have any questions or problems when setting your pinion you can refer to our video on our site or just gives us a call. Our tech dept is open till 6pm est.Thanks again.
http://www.bmrtvonline.com/video_detail.php?mId=3788
