New LS1 Owners - Newbie Tech - Minimizing powertrain loss?
Chronicle
07-16-2008, 08:19 AM
I was just wondering, what are some basics that I could start with to minimize the amount of powertrain loss in my car?
JD_AMG
07-16-2008, 12:55 PM
What kind of car do you have? Which transmission?
Regardless of the car you can minimize loss by getting lighter drivetrain components. Driveshaft, flywheel, wheels/tires.
99_SS_LS1
07-16-2008, 06:00 PM
I've got an m6 - all stock drive train with 275/40/17s, on a dynojet it only registered 31 horse loss on a 355rwhp car which equals less than 10%
It would help to get lightweight components but there are probably better things to spend money on.
Chronicle
07-17-2008, 11:49 AM
I've got an M6, if that changes anything.
angel71rs
07-18-2008, 01:07 PM
You might want to consider/check other things that can rob your power, e.g.: the front rotors on my low mile Z (low 20s at the time) looked bad for the miles, so I decided to r & r them. On both sides, the lower slide bolts were rusted in solid! Obviously this caused drag, heat, and was probably the reason for the dogged looking rotors.
Popped off the brackets, shot them with penetrant, worked the bolts loose, buffed with the wire wheel. I noticed afterwards that I could coast for a lot longer distance after letting off the gas. Something like this could maybe cost a couple mpg/tenths in the 1/4.
RsSean
07-18-2008, 01:16 PM
Go to Synthentic oils though out the drivetrain. I use Mobil one though out but never test the threoy. Royal Purple did a study with all of thier syn. oil and gained 10 horsepower at the wheel. Good show I think it came on the dicovery channel a while back.
NVR_SPDS
07-25-2008, 02:36 PM
two of the options i can think of, is a trans with the internals that are completely micropolished or mikronited, and a set of mikronited rear gears.. That, combined with the good synthetic fluids should net you some gains.
I have a built trans thats completely micropolished and cryo'd, and im making the numbers in my sig (02) with essentially a lid, catback, and 3.73s.
kerryt1
07-25-2008, 03:12 PM
Lightweight components and lower friction (better lubricants, treated surfaces) is all you can do.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
