Torque arm relocation crossmember: BMR or UMI?
Old 07-16-2008, 06:28 PM
INMY01TA's Avatar
Default Torque arm relocation crossmember: BMR or UMI?
I'm leaning more towards BMR as it appears it has more adjustibility but UMI looks to be $14 cheaper. Jeez these things are kinda exspensive. Any input is appreciated.
Old 07-16-2008, 08:32 PM
UMI Performance's Avatar
Our relocation brackets now have the built in instant center adjustment like the BMR set-up... the new pictures just aren't up yet. But they now include settings to raise and lower the front of the torque arm.
I hope that helps and if you have anymore questions please ask. Thank you!
Ryan
Old 07-16-2008, 09:23 PM
Wild Willy's Avatar
I love my UMI- not familiar with the BMR- anything you do will be an improvment over what GM did- take the torque loads off the back of the tranny, and make it easier to lay down power-
I put mine on with the 3-pt SFC's, but then I like to make sure- "too much is just enough"
Old 07-16-2008, 09:38 PM
BlackBADaSS02's Avatar
I have the UMI TA relocation kit. It has more than one set of the adjustable mounting points just like the BMR piece.
Old 07-16-2008, 11:27 PM
xdamxincx's Avatar
can someone please post a pic of the new umi adj mounting points on the relocation bracket?
Old 07-16-2008, 11:59 PM
Mojave's Avatar
UMI all the way.
Old 07-17-2008, 10:58 AM
Thanks everyone
If you have any additional questions please ask. Thank you!
Ryan
Old 07-17-2008, 10:59 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Hello, although the price may seem expensive its alot cheaper than having to replace the transmission tailshaft. We have been making out relocation crossmembers for 5 years and they have always had the instant center adjustability built into them. The crossmembers are made from .120" wall dom steel with a 1/4" thick torque arm mounting bracket. Having the ability to adjust your instant center will have a huge effect on your 60' times. We have the crossmembers in stock an ready for same day shipping. I'll post of a picture of the crossmember. If you have any questions please give us a call. Our tech/sales dept is available from 8:30AM-6:00PM EST. Mon-Fri.
http://www.bmrfabrication.com/F-bodyChassis.htm
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 07-17-2008, 11:36 AM
soulless's Avatar
Here's a few pics of mine, poor quality though.
Old 07-17-2008, 12:40 PM
Thanks for the pictures
Old 07-17-2008, 03:10 PM
toadzq8's Avatar
I got a BMR would recommend it, great fit with no header/y-pipe clearance issues
Old 07-17-2008, 03:44 PM
BMR Tech2's Avatar
Thanks for the recommendation.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 07-19-2008, 04:06 PM
SpdFrk1990's Avatar
I like my UMI relocation altho mine does not have the adjustability I have the adjustable BMR torque arm for that. Cant go wrong with either company. Car transfers power really well!
Old 07-19-2008, 04:35 PM
Soul TKR's Avatar
both companies make great products... I wouldn't be afraid of either one
Old 07-20-2008, 01:01 PM
studderin's Avatar
I really like my BMR, it has alot of adjustment. And I like that the fastest cars use BMR parts, not just the cheapest knock off copies. The car shifts so much better with the TA off the trans, at 1st it felt weird WOT like I missed the gear. But after a day you get used to the shifter not moving up, same for bumps on the hyway. Its all smooth now, the car shifts alot better.
Old 07-20-2008, 01:17 PM
SpdFrk1990's Avatar
I agree they make shifting much smoother specially coupled with the torque arm. Its a great mod def worth the money imo.
Old 07-21-2008, 10:18 AM
99345hp's Avatar
Can you use the stock torque arm with these relocation crossmembers? I dont really have the need for a aftermarket torque arm right now, but I see a lot of people say it makes the shifting easier.
Old 07-21-2008, 10:25 AM
Yes you can use the factory torque arm with the torque arm relocation kit. You just need to purchase a one piece bushing as well which can be purchased from us for $14.99, the two piece factory bushing will not work.
If I can help anymore please ask. Thank you!
Ryan
Old 07-21-2008, 11:27 AM
silverLSWON's Avatar
Ryan
does it change the pinion angle with a stock ta??
Old 07-21-2008, 11:29 AM
If you use the correct mounting hole on the relocation bracket where the torque arm attaches it will keep the pinion angle where it is now. So yes it will not effect pinion angle.
Let me know if you have any additional questions.
Thank you!
Ryan
Quick Reply: Torque arm relocation crossmember: BMR or UMI?
