Flow #s for Stock Heads?
Re: Flow #s for Stock Heads?
Jason from thunder has a print out from there superflow bench, he has it in a few of his posts do a search under his name and you will see what all the heads flow
More like 2900 for MTI S2 heads. And yes it is worth it. Everything works as a system. When I tuned and put 100 wet shot on I got 135rwhp with it! Better you breath, the faster you will run Not bad numbers for A4,12-bolt and all. And Tuned safely!
The LS6 heads will not show much gain with your stock LS1 cam. Now its a different story if you decide to drop a nice cam in it, then the stock LS6 heads will show their stuff. Now you are ready to get them ported later for even more hp.
