Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
2008 Cammed Z06 Closed vs. Open Exhaust Comparison - Video
Old 07-17-2008, 12:00 PM
LivernoisMotorsports's Avatar
Default 2008 Cammed Z06 Closed vs. Open Exhaust Comparison - Video
In this comparison, you will hear a cammed 2008 Z06 at startup, idle, and revving with the factory exhaust fuse installed and removed. In back to back dyno runs, peak numbers varied by 12 RWHP and 14 RWTQ by removing the fuse.
With the fuse removed, the vehicle picked up power across the board and substantial power down low where it's normally closed.
3,000 RPMs - Picked up 12 RWHP / 25 RWTQ
3,500 RPMs - Picked up 23 RWHP / 34 RWTQ
Up top it picked up 10 RWHp / 10 RWTQ.
Mods are:
Livernois Motorsports Stage 2 LS7 Camshaft
Livernois Motorsports Dual Valve Springs
Halltech Cold Air Intake System
Kooks Longtube Headers
Kook's X-Pipe w/ Cats
Tuned by Livernois Motorsports
Click here for the Video
Regards,
Rick LeBlanc
Old 07-17-2008, 12:49 PM
Larry's Avatar
Thanks for the info but I guess I don't understand how it picked up 10 hp on the top end. Whether the fuse is pulled or not the butterflies are open past approximately 3500 rpm. Should be no difference above this rpm. What am I missing?
Old 07-17-2008, 12:51 PM
I thought the same thing, so we did 2 pulls with the fuse and 2 without the fuse with nearly identical results.
Regards,
Rick LeBlanc
Old 07-17-2008, 12:58 PM
Larry's Avatar
Did you happen to look at the butterflies at WOT, fuse in? Maybe the factory probramming is not opening the butterflies all the way. Must be something we are missing.
Old 07-17-2008, 01:16 PM
Larry, that did cross my mind, however the car got shipped back to the customer before I could check.
-Rick
Old 07-17-2008, 01:41 PM
Larry's Avatar
Might be worth a look on the next one you get in. My 08 LS3 might have the same problem. Without putting it on a dyno it's kinda hard to tell if they are open running along behind it at WOT! LOL!
Old 07-17-2008, 02:47 PM
508Stroker's Avatar
have someone hang out of the hatch with a video camera hahaa.
Old 07-21-2008, 06:47 PM
allngn_c5's Avatar
Awesome post Rick. I am sure Fadi should will do well to read this info. As if his car isn't fast enough already.
Old 07-21-2008, 06:56 PM
allngn_c5's Avatar
Hey Rick, How about posting up the dyno sheets. I'd be very interested in seeing them.
Old 07-22-2008, 08:14 AM
Click for larger image
There was a thread on CF about NPP exhaust that did what I suspected of this exhaust. The butterflies didn't open all the way unless they were opened manually.
Regards,
Rick LeBlanc
Old 07-22-2008, 09:10 AM
allngn_c5's Avatar
Thanks Rick. The graph does a great job illustrating how much power was picked up, especially in the 3000-4000 rpm range. Nice gain everywhere but from 3-4 K she's got a monster gain in power under the curve. All that just from pulling a fuse. I need a 2008 c6zo6 LOL.
Old 07-25-2008, 10:57 AM
Fadi's Avatar
If you ever want to confrim repeatability with this test, Rick, make sure to let me know and I will be more than happy to provide you with my car. Heck, I need to dyno my car anyways.
08 Z06 with Katech cam, Kooks headers, Halltech CAI, tune.
Old 07-25-2008, 03:36 PM
Ragtop 99's Avatar
Nice improvement. Have you tried it on a bolt C6? Just curious if at 100 HP less, you get the same dramatic results.
Quick Reply: 2008 Cammed Z06 Closed vs. Open Exhaust Comparison - Video
