can i use a walbro intake with a carb
can i use a walbro 255 in tank pump in my 93 tank and run a regulator to run it with a carb or do i geed to go to a holley blue pump or somthing. I am tryin not to have to put a fuel cell in the car. if i can do this how can i hook a -8 line to the top of the stock tank or should i go with -6 line.
No, because all elec. pumps are PUSHERS not PULLERS if you see where i'm going with a PICK-UP, & the holley blue is an external pump, can't be submerged in fuel, so your options are a stock tank with sump or a cell.
You can use your 255 intake pump to feed your carb. The only thing you need to do is get a bypass regulator for a carb. I use Aeromotive part # 13204 for stuff like this. Make sure you put in a true 8AN return line so you don't have a bottle neck in the return. This setup will get you back on the road in no time.
