question bout ls7 swap
Old 07-17-2008, 10:58 PM
1992ss's Avatar
Default question bout ls7 swap
i want to do this swap, but i have a built 700r4 and i was wondering if they would work together. thanks
Old 07-18-2008, 03:42 PM
digitalsolo's Avatar
It can physically be bolted up yes. You need a special flexplate or a spacer to get the torque converter spacing correct.
To run an LS7 through a 700r4 long term, it is going to have to be VERY built, and likely rebuilt on a fairly regular basis...
Old 07-20-2008, 09:25 AM
Moderator
John B's Avatar
Your biggest problem will be getting the TV cable properly adjusted and since the LS7 uses an electronic throttle body. This will be your biggest challenge but it can be done.
