How did this happen?
The end cap bolts on the torsens blow the heads off the bolts from excessive wear and horsepower. I blew up 2 different units that way. In your case, the end cap bolt head got wedged between the case and differential where the ring gear bolt heads protrude and just knocked the heads off the ring gear bolts. One of mine almost did this but it just hammered big pieces out of a few of the bolt heads. Another bolt head just got shot out of the case. BTW, the impression of an over torque situation some are getting is because the end cap gets a large amount of pressure applied to it from abuse. Its a bit like lifting a head and stretching the bolts but in this case the bolt breaks.
