32mm sway bar bushing too tall for 30mm bushing bracket ?
Old 07-18-2008, 05:51 PM
ls1tech.fan's Avatar
Default 32mm sway bar bushing too tall for 30mm bushing bracket ?
I have a 32mm sway bar and energy suspension bushing #3.5162G (5290 stamped on bushing) that is too tall for the stock 30mm bushing bracket # 10259206 (the u shape piece that holds the bushing)
Do I need a different bracket ?
The energy suspension part did not come with a new bracket and using the old one does not work
Old 07-19-2008, 09:52 AM
giiventofly's Avatar
it should fit, i remember mine being a very tight fit.
Old 07-19-2008, 11:44 AM
Manic Mechanic's Avatar
I used washers to space the bracket out, works fine. If you clamp it down tight it will bind the sway bar up causing a rougher ride and worse handling.
Vernon
Old 08-10-2008, 01:30 PM
So washers won't weaken the bracket (u shape) or induce play, wear or looseness ?
Quick Reply: 32mm sway bar bushing too tall for 30mm bushing bracket ?
