1 wheel spinning!!
1 wheel spinning!!
I JUST GOT A ANOTHER 10 BOLT WITH 3.42 GEARS. ITS BIN GOOD SO FAR ONLY PUT 200 MILES ON SINCE I PUT IT IN WENT TO DO A BURN OUT TODAY AND ONLY LEFT ONE STRIP OF RUBBER, TRIED IT 3 MORE TIMES STILL ONLY ONE STRIP. THE ONLY THING I CAN THINK OF IS I JUST WELDED IN LCA BRACKETS AND GOT UMI LCA'S BUT I DONT SEE HOW THAT COULD CAUSE THAT TO HAPPEN
PLEASE HELP!!
PLEASE HELP!!
PLEASE HELP!!
PLEASE HELP!!
put a jackstands on rear frame jack the rear up until rear tires not touching the ground.put your shifter on neutral make sure to put blocks on the front tires so it wont move.now go back to one of your rear tire and spin it in one direction and look at the other tire.if its goin in the same direction as the one your spinning you have a posi unit.if its goin the other way or opposite it might be the cause of your one tire burnout.
V6 cars came with open differentials and also came with drum brakes. all v8 cars came with the torsen differential, and disc brakes on the rear. Only cars that had auburn units were some SLP SS cars and i believe firehawks.
