Where to purchase mandrel bent pipe??
I'm thinking about taking the time to do my exhaust myself. I want to run a x pipe off my headers and over the axles. That seems like alot of pipe work. Can I purchase some mandrel bent pipes that has all different angels. What do you'll recommend I should do?
I'm in the process of completing my true duals under the axle off my TSP duals. I'm running them to Magnaflow mufflers at the back. Just need to mount hangers and I'm done.
I used Flowmasters s-bend pipe set, which was 180 bucks I believe. Comes in pairs of 3, 5, and 8 inch offset. The best thing to do is get a chop saw and just cut the needed angles at the bend and weld on the length you need. It's really easy to do!
I picked up a grab bag of 3" mandrel mends off ebay for like $60 and it came with like 20 or so bends. I had enough to do my duals and I'm building another system for my friends Silverado.
Scott
Scott
