New FI-94X is going to the track....revisited.
Old 07-19-2008, 09:19 AM
LS1TECH Sponsor
DrTurbo's Avatar
Default New FI-94X is going to the track....revisited.
Here is the original post from Nov of last year......car was running an S88
One of our customer's e-mailed us his timeslip from this past weekend. The car is a fox body mustang running a R block and 33X ci engine...solid roller, TFS Hi-port heads, ..etc..etc. Car weighs 3181lbs.
This was on 27psi.....turbo is done though. Won't make anymore boost, and boost is dropping back to 24psi at the shift points. Car was on a decent pass until a head gasket let go. Should be a solid running car once the heads are squared away
A timeslip was posted with the S88 from the description above......Car did end up going a best of 5.15@143.XX.
The car now has a FI-94X to now meet the EZ street rules, so we should HOPEFULLY have some times shortly from him......
Attached Thumbnails New FI-94X is going to the track....revisited.-timeslipscan07.jpg
Quick Reply: New FI-94X is going to the track....revisited.
