Help HPT not working And All Kinds of Codes
My HPT keeps giving me fits is it HPT Interface ,Cords or Cars Computer?Keeps disconnecting and saying no signal to interface.I tried to Copy and Paste Codes but couldnt figure it out.I wrote some of them down...
Restraints-B1000-ECU Malfuction (History) (Immature)
Restraints-B1001-Option Config Error (History)(Immature)
Restraints-U1000-Class 2 communication Malfunction (History)(Immature)
Restraints-U1301-Class2 Short Battery (History)(Immature)
Restraints-U1016-Loss of Class 2 Communication with VCM (History)(Immature)
What do you Guys Think?
Thanks
Thanks
Moderator
It seems like something went out while connected,
to get these kind of bus error codes. Start simple,
like did the fuse pop? Inspect the connector at the
vehicle and cable end for pushed pins? That kind of
thing.
If the car starts and runs you can pretty much figure
it's not the PCM bad but a wiring fault (to include
power and connections).
thing.
I have never Had these kinds of codes before ever and I can't seem to clear them outYou know what is weird Here if I put my HPT interface in my house (air conditioned) HPT will work again.Is maybe Humidity effecting it, moisture getting into my interface?
Moderator
Those codes are jibber-jabber off the bus from things
that HPTuners doesn't touch - body control module
and the like. It sees them but it doesn't do anything
with them. The older versions did not report them, it
is just "overcommunicating" now.
If it's not PCM (or ECM and TCM on newer models)
then fuggedaboudit.
then fuggedaboudit.
