Door Hinges
Old 07-20-2008, 01:19 PM
lilblackZ28's Avatar
Default Door Hinges
Where can I buy these at?My driver door on my camaro is saging and I have to lift it up a bit to make it shut.
Old 07-20-2008, 04:22 PM
Firebird Phoenix's Avatar
Sounds like you don't even have to buy new hinges, after a while the doors can sag. Simply loosen the bolts to the hinge and have someone else at the same time hold the door up and re-tighten the bolts. You may have to repeat the process to get it just right. I hope this helps.
If you really need to buy new ones, i'm not sure if you local autoparts stores carry them (like Autozone, etc) but check out gmpartsdirect.com
Old 07-20-2008, 09:07 PM
OK Thanks
Old 07-21-2008, 10:11 PM
jester1614's Avatar
never found em at auto parts stores and they dont sell pin and bushing kits for em
dealer only
Old 07-21-2008, 10:22 PM
transambandit's Avatar
if they are the same as a t/a i have an extra one, just pay shipping on it and its yours.
Old 07-24-2008, 05:15 PM
Ok Ill pm you if I need them
Old 08-10-2008, 11:03 PM
Daedelus's Avatar
Default Verticle Hinges
I'd like to put some verticle door hinges on my '99 Firehawk TA. I've found some online, but in most of the picks it looks like the door only gets up about 45 degrees. It'd be awesome if I could just lift the door up and climb out comfortably in tight parking. Any recommendations?
Thanks
Quick Reply: Door Hinges
