Conversions & Hybrids - LS1 AC compressor with variable POA?
fast400
07-21-2008, 12:05 PM
If the POA valve is changed to this one http://cgi.ebay.com/ebaymotors/67-68-69-70-71-73-GTO-TEMPEST-LEMANS-A-C-POA-VALVE-KIT_W0QQcmdZViewItemQQcategoryZ33543QQihZ008QQitem Z180266160572QQrdZ1QQsspagenameZWDVW
The stock variable compressor should work fine...shouldn't it?
rockytopper
07-21-2008, 01:28 PM
Some folks here say you can't use the new ls1 VD compressor with older systems or that it want last. Some folks here are actually using them and have had no issues. These folks http://www.hotrodair.com
told me that they use them all the time on older systems and that vintage air and other companies are just saying they want work so you'll purchase their compressor. I purchased one of the switches locally that you are refering too. I have yet to install my A/C but will soon and am banking on it working. I do know that using this switch means you can't run the A/C thru the PCM it will be operated outside of it with your factory controls. Thru the PCM would be better sense it controls the fans, engine rpm's, better economy etc etc but is not absolutley necessary. You'd have to install the newer pressure switch like the ls1 cars use to have the pcm control it. Some folks have also done that. you have to get a block or fitting made to install it.
Oscar Will
07-21-2008, 04:51 PM
I have the variable displacement GM compressor working in a Hot Rod Air set-up. It works well with the GM (F body) pressure sensor letting the PCM control it and the cooling fan. These systems really don't care how the refrigerant gets into the evaporator as long as the pressures are correct. The variable displacement compressor allows a pretty stable pressure regulated inside the compressor, a TXV type system does basically the same thing, regulates the flow of refrigerant but it does it externally according to evaporator temperature. A CCOT system will turn on and off the compressor to keep pressures where it wants. It's all a matter of control. The fittings for the 10mm sensor are available in a number of configurations.
fast400
07-22-2008, 01:04 AM
Thanks guys.
So if I get an adaptor to make the LS1 sensor fit I can run the variable displacement compressor and control through the PCM. Sounds good!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
