Ls1 lid and airbox on lt1
I did it to my LT1, I thought it was a good mod, but I can't tell you if it made the car any faster.....it does clean up the engine bay. You will need a SS, WS6 or similar hood to make it work.
http://s229.photobucket.com/albums/e...1Image0034.jpg
^^^^You don't need a different hood for it to work. But, there will be quite a bit of cutting and you have to lay the radiator back for it to work on the stock Z28 hood.
https://ls1tech.com/forums/showthrea...ht=ls1+lt1+lid
To me id do this over any cold air out there, and take out your fogs or rig it up like the LS1 guys do to duct more air into the lid.....
Search(Free ramair more) in the LS1 section
Somone also did like 4inch PVC intake that helped, the more air and the better air flow the better.
simply swapping to an SS hood will do nothing to help clearance this mod. The spot where you'll need more room is more toward the nose and the SS hood isn't any higher at that spot than the stock Z28 hood. The Ultra Z hood will work. Maybe certain cowl hoods. If your not up for a hood swap then you'll have to do some rearranging and probably some cutting of the radiator support. As stated above, do a search on "LS1 lid LT1" and you'll find a lot of talk on this one.
ive been wanting to do it also i just need to know what i need to do to make it go with the stock parts. under the hood not the hood itself ill take care of that
http://www.lt1engine.com/tech/ls1-li...k-camaro-hood/
Not a bad tech-aid, and its for a Camaro. I don't know if the Pontiacs are going to be the same or not. Lots of pictures, but it doesn't really have "step by step" instructions. Reguardless, it looks easy enough to figure out.
That's why it's attractive to me as well. I wonder if there are clearance issues with a Firebird. I read above that there may be with a Z28. Not sure how it all lines up with the Pontiac.
