Delco Monsoon amp question
I have a RR extended range speaker that is inop. Replaced speaker, no go. Checked between wires for resistance, LR moves the needle, RR does not. I have read others post that the HU powers these two 4 ohm speakers, but the wiring diagram shows them wired to the amp- could the amp be the suspect part here? I replaced both RF and RL door speakers, and they both work just fine. I have some subs on order- i got 2 in a junkyard and one doesn't work at all, the other is very faint in both sides. I want to continue to use the factory amp here- I just want to know if it may be blown or something.
