Procharger timing issues
Old 08-25-2003, 08:25 AM
GMTuner's Avatar
Default Procharger timing issues
Hey everyone.This is my first post here.I have gotten alot of good info by searching but I have one issue yet to resolve. I have an 03 Z06 with a Procharger D-1SC and 42# injectors I am trying to tune with LS1Edit and EFILive.Overall things are going well but I have noticed that the timing advance (ADV) drops as rpms increase even though there is no KR displayed.ADV is below 10 degrees by 6krpm.The timing table in that range is set to 15 and I have the IAT table zeroed out so there is obviously something else influencing timing.It seems to me I am sacrificing a significant amount of power by not keeping the timing up higher.Any help is greatly appreciated.Let me know if you need more info.TIA
Old 08-25-2003, 02:02 PM
LS1Tech Sponsor
Slowhawk's Avatar
Default Re: Procharger timing issues
Try disabling the COT.
Old 08-25-2003, 06:14 PM
GMTuner's Avatar
Already done.I set COT Enabled = False.Any other suggestions?Is it possible that the pcm is compensating for the additional airflow and keeping the timing low? It seems like there is another table somewhere the pcm is looking at since I'm not seeing any KR.
Old 08-25-2003, 07:04 PM
LS1Tech Sponsor
Slowhawk's Avatar
If you send me your Edit file I'll look at it for you and see if I see a problem
Slowhawk@attbi.com
Could be just the timing map.
Old 08-25-2003, 07:23 PM
GMTuner's Avatar
That would be great!I'll send it right off.I also have EFILive log files if you want to take a look at those.Thanks for your help.
Old 08-25-2003, 08:30 PM
LS1Tech Sponsor
Slowhawk's Avatar
sent it back.New and improved
Old 08-26-2003, 12:43 AM
blue98coupe's Avatar
hey slowhawk do you have any experience with magnachargers ??? If you do I could use some help too
Old 08-26-2003, 07:50 PM
LS1Tech Sponsor
Slowhawk's Avatar
I've done a couple.
