Throttle position sensor A !!! problem
Old 07-22-2008, 05:05 PM
NOS USER's Avatar
Angry Throttle position sensor A !!! problem
After i did H/C swap this code came for me & my transmission shift like pig !!!!! i did swap the sensor but the problem still there!!! I`ll be thankful for your help !!!
Note, i got the hp tuner & the scanner too ..
thanks.
Old 07-23-2008, 12:24 PM
Moderator
jimmyblue's Avatar
Scan for the TPS -voltage- (not %) and see if it's
below 0.6V or above 4.7V at idle and WOT respectively.
You can do this with key on, engine off using a meter
too. TPS voltage faults will cause a "failsafe" short
shift behavior.
Old 07-23-2008, 04:52 PM
NOS USER's Avatar
Jimmyblue: If it's below 0.6V or above 4.7V at idle and WOT so what should i do to fix the problem ?
thanks.
Old 07-23-2008, 11:59 PM
Moderator
jimmyblue's Avatar
You should chase down the wiring fault if it's just whacked,
or look at why the sensor is skewed if it's only a bit outside
limits.
Old 07-24-2008, 11:03 AM
NOS USER's Avatar
Im gonna work on it , Thank you.
