cc503,306,Gm847...Best Dyno #s
Old 07-22-2008, 05:58 PM
jatsfirebird03's Avatar
Default cc503,306,Gm847...Best Dyno #s
So here we go, which cam has the best dyno #s? I have LT4 heads and was just wondering which cam will give me the most HP.
Old 07-22-2008, 06:00 PM
robsquikz28's Avatar
what is ur intake, exhaust, muffler, diameter of exhaust, any power adder, stick or auto
need more info on ur setup
Old 07-22-2008, 06:53 PM
StealthFormula's Avatar
The cc306 and GM847 will make more peak power because their durations are much larger than the cc503. The cc503 will make more power in the lower rpm's than both of them. Just because the cc306 and GM847 make more power doesn't mean that their better for your setup or will make the car faster. Same goes for the cc503 if you got a motor capable of turning real high rpms safely than it could be holding you back. All depends on your bottom end setup, where you want to spin the motor to, emissions?, and drivability etc. which all need to be answered to get a real recommendation.
Old 07-22-2008, 10:12 PM
blackz93's Avatar
Might you have a dyno graph to prove that statement?
Old 07-22-2008, 11:06 PM
Purple95Z28's Avatar
Here's a two dyno results overlayed, from the same car - red being stock heads + cam + bolt ons, blue being stock heads + GM 847 + bolt ons. I forgot who's dyno this was now but they posted it over on CZ28.com I think. As you can see the 847 actually made less power than even the STOCK cam under 3000rpm but as soon as it hit 3500 the difference was dramatic. Clearly you need a six speed car or a loose stalled automatic to make a cam like this work, even with stocks heads, as in these dyno results.
Old 07-22-2008, 11:14 PM
transam1577's Avatar
the 503 is a great cam if you have setup right!! i made 360rwhp & 402rwtq untuned @ only 5100rpm ran out of injector- i now have injectors just need to get it tune before i can throw them on. and yes i have the 503 w/stock ported heads!!!
Old 07-23-2008, 01:25 AM
zlover129's Avatar
never been much of a fan of doing stock head GM847 cam...im making just as much power...probably more with a good bit less duration. The duration is kind of like a band-aid for a poorly matched cam to the stock heads
Old 07-23-2008, 01:39 AM
Bowtie Boy's Avatar
Gm847=wont pass emissions FYI
Old 07-23-2008, 01:51 AM
LSWHO's Avatar
It'll pass here in az.
zlover129's Avatar
emissions??? what the hell is that??
Old 07-23-2008, 01:53 AM
LSWHO's Avatar
I can't tell you of a race I've ever heard of being won under 3k rpm either.
I personally couldn't care less what hp the cam makes below 3k. Big cams are for higher rpms and hp.
If you are going to spin it the 847 will OWN the others. If you won't, you'll be close and if you keep it under 6200 you'll probably lose.
Old 07-23-2008, 02:17 AM
zlover129's Avatar
^^there are people in this world that still race from a dig But yes..usually the higher peaking cam will pull, unless its a Supra in disguise. And i absolutely hate the dam expression about hp sells cars and trq wins races...just not true, just in case you guys were thinking about it
Old 07-23-2008, 10:38 AM
LSWHO's Avatar
The most illogical thing ever would be to have a stock stall with a big cam. Pretty much if you get that cam, you are nowhere near optimized with stock gearing either.
Both of those things will give you a MUCH better launch.
What I'm saying is, you should still win the launch with the 847 as long as you have modded your car "correctly." (gears in a manual, stall in an auto.)
Old 07-23-2008, 10:42 AM
slick1851's Avatar
Cookie cutter junk
Old 07-23-2008, 11:06 AM
slick1851's Avatar
I also agree, spin the motor to the rpm it needs to make its max power
If your not doing that, then youll never see what the car can truly do
Old 07-23-2008, 02:21 PM
zlover129's Avatar
very true, but people don't want to actually face the fact that you have to have supporting mods with camshafts such as gears and stalls so unfortunately many wont do them and then bitch about low power down low. I can only speak as a 6 speed owner with 4.10's, i have a smaller cam with an identical power band to the GM847 with a bit more peak power, especially with a clean ignition system now. I just was never much of a fan of any of the cams mentioned above
Old 07-23-2008, 02:30 PM
Lightbulb
I'm just curious, how does your dyno graph compare to the one I posted above?
Old 07-23-2008, 06:43 PM
well I have some other mods like 373 gears 3000 stall, hooker longtubes, borla adjustible catback and aluminum driveshaft. with MT drag radials. o and i have a lt4 intake. It has a hotcam right now and make 336rwhp on BLUECATS dyno which they say is low calibrated.
Old 07-24-2008, 01:30 AM
zlover129's Avatar
Well you can click the link in my signature to see it, and you might see why i think i picked up a decent bit of peak power with my new ignition system by looking at this graph
http://i26.photobucket.com/albums/c1...d/IMGP0999.jpg
Old 07-24-2008, 10:21 AM
blackz93's Avatar
Is that valve float, or what, at the top end?!
Quick Reply: cc503,306,Gm847...Best Dyno #s
